Tools needed to build the Rebel
pequeajim
Post by pequeajim » Sat Feb 18, 2012 2:19 pm
Here's a list of tools that I think I will need to work on my project. I am
wondering if you guys have any recommendations?
*** Items that I already have
WORKSHOP SPACE: (My garage which can be heated.)
Somewhat temperature controlled environment ***
Large flat workbench ***
Storage shelves ***
REQUIRED TOOLS
Electric hand drill ***
Drill Press ***
Bench Vice with aluminum grips ***
Sharp drill bits
Measuring tape (not metric)
Rules and square ***
Plum line ***
Level (Digital level ***)
Clecos ***
Heavy duty riveter with interchangeable heads
Good quality sheet metal snips, left hand and right hand (only have right)
Hand files, flat half round and round, (smooth cut)
Hack saw with fine teeth ***
Various clamps ***
Wrenches, ratchets, screwdrivers ***
Mike Betti
Post by Mike Betti » Sat Feb 18, 2012 2:19 pm
See my website, I think I listed the tools recomended by some others in the
group. www.mikeselite.com
Mike Betti
Sent: Sunday, November 13, 2005 6:38 PM
Subject: Tools needed to build the Rebel
am
Storage shelves ***
REQUIRED TOOLS
Drill Press ***
Sharp drill bits
Plum line ***
Clecos ***
Various clamps ***
Mike Rapoport
Post by Mike Rapoport » Sat Feb 18, 2012 2:19 pm
I think that you will be unhappy with an electric drill. You need a high
rpm air drill, the faster the better and cleaner your holes will be (mine is
6000rpm).
an angle drill is not used much but when you need it... The angle
attachments seem to require three hands.
I found that a rivet spacing fan is invaluable.
various deburring tools
Dremel
Rotozip.
rivet removal tool
A 40" shear will save a lot of time. There are only a few cuts requiring a
bigger shear. Harbor Freight has one on sale for $399 (less than $1/lb!).
If you use hand shears for everything you will have to do a lot of edge
dressing and waste a lot of material. On some parts MAM provides the
*exact* amound required and if you don't shear it you will run out. If you
don't buy a shear, try to work something out with a local sheet metal
fabricator where you can use his shear on occasion.
100 silver clecos, 300 copper, 100 black and 10 gold (for fast build)
*Lots* of clanps of various sizes and types.
cheap aluminium angle to hold things in alignment while you do something
else.
floor mounted belt sander
Metal band saw
Get the angled snips, it is easier to cut curves with them.
bench grinder with deburring wheel
Noxin center punch
LOTS of drill bits in #30 and #40
Buy 100 plain nuts in 10-32, 1/4-28, 5/16-24 and 3/8-24 so you can assemble
things quickly without nyloc nuts. Note that buying hardware in quantities
of 100 gets you a 20% discount at Aircraft Spruce.
I have bought lots of tools for this project and every one of then has been
worth it. One tip I can give you is that the riveter from Harbor Freight
works well and is very cheap! Their belt sander and band saw are cheap and
work well too.
If you are going to be buying a lot of aircraft sheet metal tools buy the US
Tool "membership card". It costs $20 and gets you free shipping and a 10%
discount. I am fortunate that my hanger neighbor owns a metalworking
factory and has a lathe and mill in his hanger. I also have a mill.on
semi-permanant loan from someone. Any of these large tools that you can get
ahold of will make life better even if you are not a machinist (as I am not.
Ebay is a good source of tools if you know what you need.
Sent: Sunday, November 13, 2005 4:38 PM
am
Storage shelves ***
REQUIRED TOOLS
Drill Press ***
Sharp drill bits
Plum line ***
Clecos ***
Various clamps ***
pequeajim
Thanks guys... All good suggestions and I will check it out. I am taking
inventory of the stuff that I picked up tonight and trying to organize as
much as I can before I bring the Fuse and wings home.
On 11/13/2005 7:03 PM, rapopor1@ix.netcom.com wrote to rebel-builders:
-> I think that you will be unhappy with an electric drill. You need a high
-> rpm air drill, the faster the better and cleaner your holes will be (mine
is
-> 6000rpm).
-> an angle drill is not used much but when you need it... The angle
-> attachments seem to require three hands.
-> I found that a rivet spacing fan is invaluable.
-> various deburring tools
-> Dremel
-> Rotozip.
-> rivet removal tool
-> A 40" shear will save a lot of time. There are only a few cuts requiring a
-> bigger shear. Harbor Freight has one on sale for $399 (less than $1/lb!).
-> If you use hand shears for everything you will have to do a lot of edge
-> dressing and waste a lot of material. On some parts MAM provides the
-> *exact* amound required and if you don't shear it you will run out. If you
-> don't buy a shear, try to work something out with a local sheet metal
-> fabricator where you can use his shear on occasion.
-> 100 silver clecos, 300 copper, 100 black and 10 gold (for fast build)
-> *Lots* of clanps of various sizes and types.
-> cheap aluminium angle to hold things in alignment while you do something
-> else.
-> floor mounted belt sander
-> Metal band saw
-> Get the angled snips, it is easier to cut curves with them.
-> bench grinder with deburring wheel
-> Noxin center punch
-> LOTS of drill bits in #30 and #40
-> Buy 100 plain nuts in 10-32, 1/4-28, 5/16-24 and 3/8-24 so you can assemble
-> things quickly without nyloc nuts. Note that buying hardware in quantities
-> of 100 gets you a 20% discount at Aircraft Spruce.
-> I have bought lots of tools for this project and every one of then has been
-> worth it. One tip I can give you is that the riveter from Harbor Freight
-> works well and is very cheap! Their belt sander and band saw are cheap and
-> work well too.
-> If you are going to be buying a lot of aircraft sheet metal tools buy the
US
-> Tool "membership card". It costs $20 and gets you free shipping and a 10%
-> discount. I am fortunate that my hanger neighbor owns a metalworking
-> factory and has a lathe and mill in his hanger. I also have a mill.on
-> semi-permanant loan from someone. Any of these large tools that you can
get
-> ahold of will make life better even if you are not a machinist (as I am
not.
-> Ebay is a good source of tools if you know what you need.
-> Mike
-> From: <pequeajim@dcsol.com>
-> Sent: Sunday, November 13, 2005 4:38 PM
-> Subject: Tools needed to build the Rebel
-> > Here's a list of tools that I think I will need to work on my project. I
-> > am
-> > wondering if you guys have any recommendations?
-> > *** Items that I already have
-> > WORKSHOP SPACE: (My garage which can be heated.)
-> > Somewhat temperature controlled environment ***
-> > Large flat workbench ***
-> > Storage shelves ***
-> > REQUIRED TOOLS
-> > Electric hand drill ***
-> > Drill Press ***
-> > Bench Vice with aluminum grips ***
-> > Sharp drill bits
-> > Measuring tape (not metric)
-> > Rules and square ***
-> > Plum line ***
-> > Level (Digital level ***)
-> > Clecos ***
-> > Heavy duty riveter with interchangeable heads
-> > Good quality sheet metal snips, left hand and right hand (only have
right)
-> > Hand files, flat half round and round, (smooth cut)
-> > Hack saw with fine teeth ***
-> > Various clamps ***
-> > Wrenches, ratchets, screwdrivers ***
-> > List archives located at: https://www.dcsol.com/login
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 2:19 pm
I have used a Panasonic cordless drill to build the tail surfaces and 1.5
wings so far. I'm sure an air drill is better in many ways, but I don't have
to run a monster compressor all the time which is a huge bonus for me. As
far as cordless drills go the Panasonic is great!
Ditto on the angle attachment. I got one on ebay that came with a bunch of
threaded bits. It is really a handy tool sometimes.
Jesse
Subject: Re: Tools needed to build the Rebel
Date: Sun, 13 Nov 2005 20:03:13 -0800
is
6000rpm).
Dremel
Rotozip.
rivet removal tool
else.
Metal band saw
Noxin center punch
work well too.
US
get
not.
am
Storage shelves ***
REQUIRED TOOLS
Drill Press ***
Sharp drill bits
Plum line ***
Clecos ***
right)
Various clamps ***
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:22 pm
I built my entire first Rebel with a cordless drill (Makita) and like you
say Jesse... more than satisfactory. Really nice when you're down the
tailcone and not dragging a hose either! If you've got a good supply of
spare batteries to keep going while batteries cool and then recharge why
drive your neighbours nuts. I use an air drill all the time now...but my
compressor is over in the hangar so I can't even hear it run when I'm in the
shop.
Doing a single airplane...you'll do just fine with a left and right hand
pair of snips. I could never go back to that with my carpal tunnel/
arthritic hands though at this stage and get lots of use from my 4 foot and
12 foot pneumatic shears.
Sent: Monday, November 14, 2005 11:45 AM
have
Jesse
is
6000rpm).
Dremel
Rotozip.
rivet removal tool
$1/lb!).
you
else.
Metal band saw
Noxin center punch
assemble
quantities
been
work well too.
US
10%
get
not.
am
Storage shelves ***
REQUIRED TOOLS
Drill Press ***
Sharp drill bits
Plum line ***
Clecos ***
right)
Various clamps ***
Jean Poirier
Post by Jean Poirier » Sat Feb 18, 2012 2:22 pm
I am building my firts (and probably the only!) Rebel. I have all drills
(electric, battery, air). For myself (and I have nothing to teach to
anyone else) there is just one drill: 1/4" capacity air drill with a little
3/16" air hose. Light, fast and cheap to buy. My 90 degree mini die
grinder and that drill will probably are so usefull...
I have a old/big/slow turning air compressor. Less noisy thant $700.00
price club new ones (and probably more tuff).
Jean
Rebel 747R
Sent: Monday, November 14, 2005 1:47 PM
shop.
have
Jesse
high
(mine
is
6000rpm).
Dremel
Rotozip.
rivet removal tool
$1/lb!).
you
else.
Metal band saw
Noxin center punch
assemble
quantities
been
Freight
work well too.
US
10%
get
not.
I right)
pequeajim
Post by pequeajim » Sat Feb 18, 2012 2:22 pm
Good ideas guys... Thanks
On 11/14/2005 9:47 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> I built my entire first Rebel with a cordless drill (Makita) and like you
-> say Jesse... more than satisfactory. Really nice when you're down the
-> tailcone and not dragging a hose either! If you've got a good supply of
-> spare batteries to keep going while batteries cool and then recharge why
-> drive your neighbours nuts. I use an air drill all the time now...but my
-> compressor is over in the hangar so I can't even hear it run when I'm in
-> shop.
-> Doing a single airplane...you'll do just fine with a left and right hand
-> pair of snips. I could never go back to that with my carpal tunnel/
-> arthritic hands though at this stage and get lots of use from my 4 foot and
-> 12 foot pneumatic shears.
-> Wayne
-> From: "Jesse Jenks" <jessejenks@hotmail.com>
-> Sent: Monday, November 14, 2005 11:45 AM
-> Subject: Re: Tools needed to build the Rebel
-> > I have used a Panasonic cordless drill to build the tail surfaces and 1.5
-> > wings so far. I'm sure an air drill is better in many ways, but I don't
-> have
-> > to run a monster compressor all the time which is a huge bonus for me. As
-> > far as cordless drills go the Panasonic is great!
-> > Ditto on the angle attachment. I got one on ebay that came with a bunch
-> > threaded bits. It is really a handy tool sometimes.
-> > Jesse
-> > >From: "Mike Rapoport" <rapopor1@ix.netcom.com>
-> > >Reply-To: <rebel-builders@dcsol.com>
-> > >To: <rebel-builders@dcsol.com>
-> > >Subject: Re: Tools needed to build the Rebel
-> > >Date: Sun, 13 Nov 2005 20:03:13 -0800
-> > >I think that you will be unhappy with an electric drill. You need a
high
-> > >rpm air drill, the faster the better and cleaner your holes will be
(mine
-> > >is
-> > >6000rpm).
-> > >an angle drill is not used much but when you need it... The angle
-> > >attachments seem to require three hands.
-> > >I found that a rivet spacing fan is invaluable.
-> > >various deburring tools
-> > >Dremel
-> > >Rotozip.
-> > >rivet removal tool
-> > >A 40" shear will save a lot of time. There are only a few cuts requiring
-> a
-> > >bigger shear. Harbor Freight has one on sale for $399 (less than
-> $1/lb!).
-> > >If you use hand shears for everything you will have to do a lot of edge
-> > >dressing and waste a lot of material. On some parts MAM provides the
-> > >*exact* amound required and if you don't shear it you will run out. If
-> you
-> > >don't buy a shear, try to work something out with a local sheet metal
-> > >fabricator where you can use his shear on occasion.
-> > >100 silver clecos, 300 copper, 100 black and 10 gold (for fast build)
-> > >*Lots* of clanps of various sizes and types.
-> > >cheap aluminium angle to hold things in alignment while you do something
-> > >else.
-> > >floor mounted belt sander
-> > >Metal band saw
-> > >Get the angled snips, it is easier to cut curves with them.
-> > >bench grinder with deburring wheel
-> > >Noxin center punch
-> > >LOTS of drill bits in #30 and #40
-> > >Buy 100 plain nuts in 10-32, 1/4-28, 5/16-24 and 3/8-24 so you can
-> assemble
-> > >things quickly without nyloc nuts. Note that buying hardware in
-> quantities
-> > >of 100 gets you a 20% discount at Aircraft Spruce.
-> > >I have bought lots of tools for this project and every one of then has
-> been
-> > >worth it. One tip I can give you is that the riveter from Harbor
Freight
-> > >works well and is very cheap! Their belt sander and band saw are cheap
-> and
-> > >work well too.
-> > >If you are going to be buying a lot of aircraft sheet metal tools buy
-> > >US
-> > >Tool "membership card". It costs $20 and gets you free shipping and a
-> 10%
-> > >discount. I am fortunate that my hanger neighbor owns a metalworking
-> > >factory and has a lathe and mill in his hanger. I also have a mill.on
-> > >semi-permanant loan from someone. Any of these large tools that you can
-> > >get
-> > >ahold of will make life better even if you are not a machinist (as I am
-> > >not.
-> > >Ebay is a good source of tools if you know what you need.
-> > >Mike
-> > >----- Original Message -----
-> > >From: <pequeajim@dcsol.com>
-> > >Sent: Sunday, November 13, 2005 4:38 PM
-> > >Subject: Tools needed to build the Rebel
-> > > > Here's a list of tools that I think I will need to work on my
project.
-> > >I
-> > > > am
-> > > > wondering if you guys have any recommendations?
-> > > > *** Items that I already have
-> > > > WORKSHOP SPACE: (My garage which can be heated.)
-> > > > Somewhat temperature controlled environment ***
-> > > > Large flat workbench ***
-> > > > Storage shelves ***
-> > > > REQUIRED TOOLS
-> > > > Electric hand drill ***
-> > > > Drill Press ***
-> > > > Bench Vice with aluminum grips ***
-> > > > Sharp drill bits
-> > > > Measuring tape (not metric)
-> > > > Rules and square ***
-> > > > Plum line ***
-> > > > Level (Digital level ***)
-> > > > Clecos ***
-> > > > Heavy duty riveter with interchangeable heads
-> > > > Good quality sheet metal snips, left hand and right hand (only have
-> > >right)
-> > > > Hand files, flat half round and round, (smooth cut)
-> > > > Hack saw with fine teeth ***
-> > > > Various clamps ***
-> > > > Wrenches, ratchets, screwdrivers ***
-> > > > List archives located at: https://www.dcsol.com/login
-> > > > username "rebel" password "builder"
-> > > > Subscription services located at:
-> > > > https://www.dcsol.com/public/code/html-subscribe.htm
-> > > > List administrator: mike.davis@dcsol.com
-> > > List archives located at: https://www.dcsol.com/login
-> > > username "rebel" password "builder"
-> > > Subscription services located at:
-> > > https://www.dcsol.com/public/code/html-subscribe.htm
-> > > List administrator: mike.davis@dcsol.com
Jean Poirier
Oups!
Someone say 100 silver clecos and 300 copper..... I have now 450 silver
ones and same amount of copper... and I am always "out of stock" I can't
imagine building a wing ( I am doing the second one) with a minimum of 400
silvers. With the basic tool kit I have received 250 of each and it is a
"basic" kit. 2 cents opinion
Jean
Rebel 747R
Sent: Monday, November 14, 2005 3:30 PM
you
why
my
in
-> shop.
hand
-> Wayne
1.5
don't
-> have
me. As
bunch
-> > Jesse
high
(mine
-> > >is
-> > >6000rpm).
-> > >Dremel
-> > >Rotozip.
requiring
-> a
-> $1/lb!).
edge
If
-> you
metal
build)
something
-> > >else.
-> assemble
-> quantities
has
-> been
Freight
cheap
-> and
buy
-> > >US
-> 10%
metalworking
mill.on
can
-> > >get
am
-> > >not.
-> > >Mike
project.
-> > >I
-> > > > am
-> > > > Clecos ***
have
-> > >right)
Mike Rapoport
Post by Mike Rapoport » Sat Feb 18, 2012 2:22 pm
I cheated and bought the fast build kit!
Sent: Monday, November 14, 2005 12:45 PM
Oups!
Jean
Rebel 747R
you
why
my
in
-> shop.
hand
foot
-> Wayne
1.5
don't
-> have
me. As
bunch
-> > Jesse
high
(mine
-> > >is
-> > >6000rpm).
-> > >Dremel
-> > >Rotozip.
requiring
-> a
-> $1/lb!).
edge
If
-> you
metal
build)
something
-> > >else.
-> assemble
-> quantities
has
-> been
Freight
cheap
-> and
buy
-> > >US
-> 10%
metalworking
mill.on
you
can
-> > >get
am
-> > >not.
-> > >Mike
project.
-> > >I
-> > > > am
-> > > > Clecos ***
have
-> > >right)
