Brake pressure in Rebel/Elite ?
N.Smith
Hi All
Any one got any idea the max pressure likely to be encountered in the brake
system of the Rebel or Elite ?
Just looking at alternative brake lines and wondered if 1000 PSI would in
fact be OK ?
Nigel
745E
fact be OK ?
Nigel
745E
Hi Nigel
When I did my brakes I concluded that the normal max operating pressure
was probably not more than about 300 psi. I think that was about the max
I saw on the Matco brake simulator once as well but don't trust my
memory too far...
If I thought it would ever reach 1000 I would have thrown the 1/4"
plastic lines away.
memory too far...
plastic lines away.
Smith wrote:
Hi All
fact be OK ?
Nigel
745E
Alan Hepburn
I didn't even consider using the plastic lines supplied - except for the
supply lines from the reservoir to the master cylinders. I used stainless
braided lines for the high pressure section. I have Cleveland brakes on
Montana 2200 amphibs.
Al
Al
At 04:15 PM 11/13/2005 -0000, you wrote:
service without any problems. I assume you already have the parts. Any
alternative material will undoubtedly weigh more and slow down your build
time as you source all the parts.
Uh Why? The plastic lines are light cheap and effective. Lots of them inHi All
fact be OK ?
Nigel
745E
Hi Drew
I think Angus has blown both brake lines and float hydraulic lines.
fact be OK ?
Nigel
745E
If you overheat a brake disc/caliper it can soften the nylon and allow it to
pop out of the fitting. Usually only an issue with HP aircraft but very
possible with an amphib if you are having trouble steering and constantly
dragging one brake. Howard's went 7+ summers with no line problems
though..brakes or gear hydraulics. I have had no problems over 10+ years
with mine of wheels using the 1/4" Parker parflex and no problems this
summer with my brakes or hydraulics on the amphibs.
Sent: Sunday, November 13, 2005 11:02 PM
Subject: Re: Brake pressure in Rebel/Elite ?
brakeHi Drew
Hi All
insystem of the Rebel or Elite ?
Uh Why? The plastic lines are light cheap and effective. Lots of them infact be OK ?
Nigel
745E
At 11:02 PM 11/13/2005 -0500, you wrote:
were not as high quality lines or fittings as the brake lines though. I
thoughr Angus went with all aluminum lines on his origional instalation.
I ended up replacing all my float hydraulic lines because of leaks. TheyHi Drew
Angus McKenzie
Hi Ken and Drew
The hydraulic lines in the cockpit blew in several spots and the brake lines
have blown about 3 times once on wheel gear and twice on floats. So, now we
have braided stainless and solid aluminum from your feet to the calipers for
the brakes, this made a significant improvement increasing brake efficiency.
The plastic lines on the hydraulic float pump have blown on the pressure
side in three spots, (our Rebel will leak oil out of the fuselage on hot
days for the rest of its life, I should probably reweigh it and do a W&B
amendment for the spilled oil onboard) anyway, I now have solid aluminum
from the pump to the floats but still have plastic lines in the floats,
though I expect to replace that plastic line as well.
My most recent structural "need" is doublers at the front of the rear corner
wraps under the door sill.
Sorry to have missed the get-together in Brampton on Sunday-family issues.
Angus..............049R
Sent: Monday, November 14, 2005 8:30 AM
Checked by AVG Anti-Virus.
Version: 7.0.289 / Virus Database: 265.0.0 - Release Date: 11/8/2004
At 11:02 PM 11/13/2005 -0500, you wrote:I ended up replacing all my float hydraulic lines because of leaks. TheyHi Drew
N.Smith
Thanks Angus
Can you remember the spec no for the braided stainless flexible or it's max
pressure rating ?
Nigel
745E
Angus McKenzie
Sent: 14 November 2005 19:02
Hi Ken and Drew
pressure rating ?
Nigel
745E
Angus McKenzie
Hi Ken and Drew
Angus McKenzie
Hi Nigel
Just called the supplier, a commercial hose and fitting distributor, Hose
Headquarters,London, ON. with your query........919 series hose, 1/4"ID
teflon tube-braided stainless jacket.
Spec.no. 100R14A
3000psi working pressure
x4 for burst pressure
working temps -100F or -73C.
+450F.or +232C.
This is ........NOT.......... AN-hardware. Just industrial material.
Regards, Angus
Sent: Monday, November 14, 2005 2:40 PM
Subject: RE: Brake pressure in Rebel/Elite ?
Spec.no. 100R14A
+450F.or +232C.
Regards, Angus
Thanks Angus
max
pressure rating ?
Nigel
745E
Angus McKenzie
Hi Ken and Drew
lines
we
for
efficiency.
corner
N.Smith
Thanks Angus
Nigel
Angus McKenzie
Sent: 14 November 2005 20:01
Hi Nigel
Spec.no. 100R14A
+450F.or +232C.
Regards, Angus
Nigel
Angus McKenzie
Hi Nigel
Spec.no. 100R14A
+450F.or +232C.
Regards, Angus
Thanks Angus
max
pressure rating ?
Nigel
745E
Angus McKenzie
Hi Ken and Drew
lines
we
for
efficiency.
corner
...unfortunately MAM is throwing Beige Semi-rigid nylon tube in the amphib
kits now (well at least the one I got last Thur) instead of the ship list
Parker Parflex...me not amused with being expected to try something
different (and I won't be)! I know what you're saying about bubble chasing,
Walter, with the semi-clear parker parflex. Very easy to coax it up the
struts. Once you get it up towards the cabin you can cycle back and forth
partially to get it into the reservoir without pushing the air back down to
the floats.
Sent: Monday, November 21, 2005 11:39 PM
the floats.
I still have the original MAM plastic brake and hydraulic lines
in mine, and no problems since I solved the original fitting
leaks when first installed. One thing I do with mine that might
help, is I leave the valve lever in the middle/lock position,
which may relieve pressure on my lines.
Another advantage of the plastic lines is that you can see air
bubbles which were easy to get rid of then after installation
without having to bleed any lines. I retracted the front wheels
and then tilted the plane up or down to slowly move the air
bubbles where I wanted them to go.
Angus McKenzie
Sent: Monday, November 14, 2005 11:03 AM
Hi Ken and Drew
the fuselage on hot
have solid aluminum
hydraulic lines.At 11:02 PM 11/13/2005 -0500, you wrote:because of leaks. TheyI ended up replacing all my float hydraulic linesbrake lines though. Iwere not as high quality lines or fittings as theorigional instalation.thoughr Angus went with all aluminum lines on his-------------------------------------------------------Drew
-----------------------------------------------------------------List archives located at: https://www.dcsol.com/login
----------Date: 11/8/2004
Date: 11/8/2004
Whats wrong with a little air in the lines? I figure the air bubbles
compress and will help hold the pressure as they expand if you've got a
slow leak.
slow leak.
Drew...unfortunately MAM is throwing Beige Semi-rigid nylon tube in the amphib
the floats.
Bruce Georgen
After blowing my float line in BC last summer, after setting in the hot sun for several hours while fishing with Walter, I leave my selector in the up position. When in the neutral position I still get pressure build up.
Bruce
Sent: Nov 21, 2005 11:43 PM
the floats.
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
Bruce
the floats.
Angus McKenzie
Hi Ken and Drew
the fuselage on hot
have solid aluminum
Date: 11/8/2004
PeoplePC Online
Angus McKenzie
Hi Ken and Drew
the fuselage on hot
have solid aluminum
hydraulic lines.At 11:02 PM 11/13/2005 -0500, you wrote:Hi Drew
I think Angus has blown both brake lines and floatbecause of leaks. TheyI ended up replacing all my float hydraulic linesKenbrake lines though. Iwere not as high quality lines or fittings as theorigional instalation.thoughr Angus went with all aluminum lines on his-------------------------------------------------------Drew
Date: 11/8/2004
