Installation off wings.
Posted: Sat Feb 18, 2012 5:18 pm
Gooday to everyone.Need your help again.
Will be installing wings in a couple off months or so.Problem is shed is not large enough to install both wings at once.Will this work.Install one
wing connect all controls wiring fuel lines etc.Using split flaps Have controls installed in cabin get everything as functional as possible,remove wing & do same for other.Complete all other work including install off 2150 full lotus paint wings & fus transport to hanger install wings ,make minor adjustments [ Hopefully minor] and the fun begins.
If i cannot do this i will have to build a piece on shed before winter starts.
Also does anyone know height off rebel tail while sitting oe 2150 full lotus.
Is aircraft stable enough to work on with one wing attached,or does it have to be blocked.
Regards;Alvin Adams
Gander NF R 776
Regards;Alvin Adams
Gander NF R 776
