Pro seal again
apoulsen
Pro seal again
Post by apoulsen » Sat Feb 18, 2012 2:07 pm
Hey everyone,
Lots of stuff in the archives yet after trying to use the stuff yesterday I'm still mystified how you guys spread it on mating surfaces. I spoke with the chemist at PRC DeSoto and was told emphatically that type B should not be used between skins and ribs in that if is formulated for fileting. Type C is a thinner formulation designed for this use but Spruce only sells one type so are you guys doing something with the type B to get it on the mating surfaces or are you using two different formulations for the tanks?
Thanks for the help.
Allen Poulsen
786R
Pro seal again
Post by Wayne G. O'Shea » Sat Feb 18, 2012 2:07 pm
The chemist has probably never built an airplane either :O)
B works just fine Allen. Guys here will tell you they use B and brushable
and some thinned etc. I use it just the way it comes out of the can (10/1 by
volume) mixed with a putty knife on a scrap piece of aluminum and spread
with the putty knife on rib flanges and Popsicle sticks to fillet seams. Has
NEVER been a problem!
Sent: Thursday, November 03, 2005 9:04 PM
Subject: Pro seal again
Hey everyone,
Allen Poulsen
786R
Jeff McMurrer
Pro seal again
Post by Jeff McMurrer » Sat Feb 18, 2012 2:07 pm
Allen,
Class B I used mostly everywhere, applied using a 1x3 inch paint roller (cut the roller into 1 inch pieces) covers the area needed without excess mess. Used the same method applying zinc chromate as well.
Class B can be reduced with a chemical called toluene (max thinning of 15% by volume), have done this when no Class A at hand.
Best of luck to you.
Jeff
Date: Thursday, November 3, 2005 6:04 pm
Hey everyone,
the tanks?
Allen Poulsen
786R
Pro seal again
Post by Ken » Sat Feb 18, 2012 2:07 pm
Screw driver, acid brush, popsicle stick, finger (two pairs of latex gloves)
B is fine with the thick pieces of material we build our tanks out of
and lets you filet at the same time.
The chemist would be correct if you were talking about joining .020
skins and greater rivet spacing.
apoulsen wrote:
Hey everyone,
Allen Poulsen
786R
Mike Rapoport
Pro seal again
Post by Mike Rapoport » Sat Feb 18, 2012 2:07 pm
As long as we are on the topic of adhesives, what did everybody use between
the door skin and the doubler that goes around the edges?
Steve Halvorsen
Pro seal again
Post by Steve Halvorsen » Sat Feb 18, 2012 2:07 pm
Mike:
We used Pro-Seal and it seemed to work very well. Have to let it set for a couple of days to cure tho. Held up good during the trimming of the excess metal to make the doors fit.
Steve H
Moose 213
Pro seal again
I shouldn't fire off quick answers anymore Mike...
however if you mean those sealing strips about an inch or so wide around
the outside edges of the door -mine are slipped between the door skin
and the frame and rivetted with epoxy primer.
Mike Rapoport
Pro seal again
Sent: Friday, November 04, 2005 10:22 AM
Subject: Re: Pro seal again
between
Those are the ones! I have been mentally debating whether to use epoxy
primer (easy and clean) or proseal (always a mess for me).
Thanks!
Mike Rapoport
Pro seal again
Thanks Steve!
Sent: Friday, November 04, 2005 10:18 AM
Mike:
Steve H
Moose 213
between
Pro seal again
Proseal does a good job. Rivet it together and leave clamped with spring
clamps around the perimeter till it cures. Clean the edge with a knife
afterwards. U are referring to the door jam overlap on the door skins where
you reinforce with .032 or similar?
Sent: Friday, November 04, 2005 12:45 PM
between
jtpackard
Pro seal again
Post by jtpackard » Sat Feb 18, 2012 2:07 pm
Mike:
I used 3M DP-190 epoxy. Not as flexible as Pro-Seal, but not as rigid
(higher modulus) as some epoxies. If I was not a retired 3M employee, I'd
probably use Pro Seal.
Tom Packard
SR043
Sent: Friday, November 04, 2005 11:45 AM
between
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
