Moose tail: Question on FUS-436L & 436R
Scott Aldrich
Post by Scott Aldrich » Sat Feb 18, 2012 2:06 pm
Ted, are the brackets FUS-436L and 436R that the pivot ball (FUS-437) mounts
into still aluminum? Weren't the mount holes on those wowed out on some
aircraft (both around the ball and where they mount to the fin (Bob
Howells)?? I know someone out there has made their own out of steel (that
may have been Bob also). I agree the FUS-438 could be left out. I remember
being told once that was the "fix" to stop it from cracking, cut it off or
leave it out.
Scott
Moose 174
Ted Waltman
Post by Ted Waltman » Sat Feb 18, 2012 2:06 pm
Yes, the FUS-436L+R are still aluminum; there is no update (to my
knowledge) to these brackets.
No, I did not see any "wowing" or hole enlargement on the FUS-436L+R
brackets--where they mount to the pivot (FUS-437). There's no way (that
I can imagine) the 8 (?) mounting holes in FUS-436 would enlarge--if so
one would have a major, major problem!
I didn't mean to imply that the FUS-438 could be totally left out...just
that one would probably be Ok using the existing aluminum one rather
than the new steel one.
Scott Aldrich
Sent: Monday, October 31, 2005 10:46 AM
Subject: Moose tail: Question on FUS-436L & 436R
mounts into still aluminum? Weren't the mount holes on those wowed out
on some aircraft (both around the ball and where they mount to the fin
(Bob Howells)?? I know someone out there has made their own out of
steel (that may have been Bob also). I agree the FUS-438 could be left
out. I remember being told once that was the "fix" to stop it from
cracking, cut it off or leave it out.
Scott
Moose 174
Scott Aldrich
You didn't imply that the FUS-438 could be left out, my bad, poor wording
when I said I agree. I guess what I meant was the bottom part really does
nothing structurally and that is why Darryl suggested not riveting the wrap
to it or cutting it off (but leaving the upper part on the fin).
Scott
Waltman
Sent: Monday, October 31, 2005 11:03 AM
Subject: RE: Moose tail: Question on FUS-436L & 436R
Scott Aldrich
Scott
Moose 174
