Rebel: Scott 3200 Tailwheel
Posted: Sat Feb 18, 2012 5:01 pm
Hi Ian !
Think that was Wayne's comment ....
But I have flown at least one that had a thick (1/8"+) piece
of rubber above & below the spring - think it was cut from the
sidewall of a tire, and clamped in quite tightly. Guess the idea
was to give a bit of cushioning .... but you sure don't want
any side play !
On Sunday 16 October 2005 03:03 am, IAN DONALDSON wrote:
any side play !
aG'day Bob
I had to go and get the manual to refresh my memory and there certainly is
made"bathtub" fitting on the Fus-49.
However the tail spring is held in place between the TS-1 bolts with
multiple pieces of aluminum. Is this still satisfactory or has someone
ina tidier way of fitting this all together.
regards
Ian Donaldson
Ian..would suspect U already have the 2 piece motor mount style fitting
the tail. The early Rebels had a multi layer of alum strap that held the
bolt and no bath tub fitting attached to the Fus-49.
