system' as opposed to 'port injection'? If so, the atomization of the fuel
(at the throttle body) removes a lot of heat, as it does with carburetors.
Pour some gas on your hand and see how cool it feels as it evaporates. I
don't recall ever seeing a port injected engine with a heated throttle
body... car or airplane. If the bird is port injected, then Ford just saved
a couple of bucks by utilizing an old intake manifold from a carbureted
engine.
Bill Delcambre
On 9/13/05, Wayne G. O'Shea <oifa@irishfield.on.ca> wrote:
eGot to thinking while I was tearing away on Daryl's '90 T-Bird SC over th
last few hours...trying to find and remove a rocker cover.......
if most everyone states for aircraft usage that throttle bodies and fuel
injection don't need "carb heat' to prevent icing then why does the
throttle
body on the TBird have an engine coolant line running thru it right under
the butterfly valve??
