fuel fitting sealant
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 10:59 am
I got a product from ACS that is called EZ Turn. They said it is the
replacement for Fuel Lube if any of you are familiar with that product. I
got it for use on all the pipe thread connections out of the tanks, but I am
wondering if I should use it on flare fittings as well?
Jesse
Post by Drew Dalgleish » Sat Feb 18, 2012 10:59 am
On a flair fitting you want metal to metal contact in order to get a good
seal. A light smear on the threads of the fitting will help prevent
corrosion and let you take it apart some day if required. I use a locktite
product thats fuel proof just because that's what I have in my toolbox
after working for a gas fitter.
Jesse
Jesse Jenks
Good info. Thanks Drew.
Subject: Re: fuel fitting sealant
Date: Wed, 07 Sep 2005 21:42:53 -0400
am
Jesse
