EDGE DISTANCE; TORQUE ARM
Posted: Fri Feb 17, 2012 7:20 pm
Received: from chucks.gte.net (1Cust72.tnt4.krk1.da.uu.net [208.254.1.72])
by smtp2.mailsrvcs.net with SMTP id KAA21585
for <murphy-rebel@dcsol.com>; Sun, 29 Mar 1998 10:41:18 -0600 (CST)
Subject: Fw: EDGE DISTANCE; TORQUE ARM
Date: Sun, 29 Mar 1998 08:39:58 -0800
Message-ID: <01bd5b31$4fbc2f60$4801fed0@chucks.gte.net>
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.71.1712.3
X-MimeOLE: Produced By Microsoft MimeOLE V4.71.1712.3
To: CaptVictor@aol.com <CaptVictor@aol.com>; cbrd@zeuter.com
<cbrd@zeuter.com>; ccrawfor@linknet.kitsap.lib.wa.us
<ccrawfor@linknet.kitsap.lib.wa.us>; cdenny@mindspring.com
<cdenny@mindspring.com>; chucks@gte.net <chucks@gte.net>; cimaut@ven.net
<cimaut@ven.net>; Clarapegg@aol.com <Clarapegg@aol.com>; croft@islandnet.com
<croft@islandnet.com>; CWS1932@aol.com <CWS1932@aol.com>; MMoreho699@aol.com
<MMoreho699@aol.com>
Date: Sunday, March 29, 1998 12:21 AM
Subject: EDGE DISTANCE; TORQUE ARM
MIME-Version: 1.0
X-Priority: 3
it'sHello!
In building my torque arm I am asked to drill a #11 hole through a 2.25"
sleeve, the torque tube and the end plug (EL-31). I am asked to space this
1/2" from the end of the tube. The plug extents 13/16" into the tube from
andcollar to the end of the plug. So this places the hole 5/16" from the end
I1/2" from the collar.
But the #11 hole is .191" with edge distance of .382". Since 5/16" = .3125
Ican't safely do this.
Calculation for edge distance with a #11 hole: going rootward I would have
.382 and .382 tipward, or .764" for minimum length. 13/16 = .8125 That's
cutting it pretty tight in my book. Are my calculations correct?
I also may need some control horns or fabricate them. What are their specs?
push-have some ones that the holes were drilled too close to the edge, using
similar numbers as above. I could just trace them out of stock aluminum.
Also my clearance between the control horn going through the bottom of the
wing to the skin is 1/16". Is this enough?
Concerning the push-pull tube to flaperon control horns connection: my
pull tube looks different than figure 79 of 7/27/94 Rebel manual. In the
manual, it looks like the flaperon horns are nearly flush with the Rod End
Bearings (HM-4M). I have a 1/8" gap between the outsides of the rod end
bearing and the flaperon horns. Problem?
Dan
R280
