hoses either, we took the aluminized exhaust pipe made nice neat bends laid
in place and used short hoses at each end made a very nice job. Just a
thought. Dale SR-033
Sent: Wednesday, August 31, 2005 10:29 PM
Subject: Radiator hose tricks
I finished installing my radiator below the engine up against the firewall.
Then I learned something about radiator hose. The big sizes can't be
routed. I proceeded on the premise that I could buy 1-1/2 and 1-3/4 hose
and route it from my radiator to the water pump and the thermostat
housing.
Then when I went looking for some hose I discovered you can only get
straight pieces locally in 3 or 4 foot lengths and you can't bend them
more
than a few degrees without kinking. Arrrgggghhh! There are a couple of
possibilities I found on the web for hose that can be bent more than
standard hose but it's iffy. I decided to go down to the local auto parts
store and see if they'd let me poke around and see if there are any
pre-bent
pieces off-the-shelf that might work. I cut and bent some copper tubing
the correct shape and off to the auto parts store. Believe it or not I
found two pieces that would work just fine if not for one thing. They
have
one end expanded to the correct size but the rest of the hose and the
other
end is too small. Anybody know how the end of a radiator hose is expanded
and if there might be a way to do it in one's shop?
044SR
