Counter Sunk Anchor nuts
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:58 am
Yes Ben..there is! I know I have 10-32's (AN366-F1032C/S) that have C/S
rivet holes. Next trip out to the hangar I'll see what else is there if I
get time.
Sent: Friday, August 26, 2005 12:41 PM
Subject: Re: Filler neck install
Jesse,
FWIW, I installed mine on the inside. Me and others that stop by to look
at
my plane for the 5 years before it flies will admire the cleaner look. ;)
On another front... is there such a thing as anchor nuts with the 3/32
rivet
holes dimpled or CS?
-Ben/496R
Thanks Walter and Wayne.
Date: Thu, 25 Aug 2005 23:35:44 -0400
10+ years, 500 hours of fuel fills and just starting to get a bit
loose....but only 'cause the rubber seals have shrunk...but still not
letting any water in.
I've done them both ways and I guess outside makes more sense from the
replacement point of view...look better inside as you say..but also
like
you
say only the guy with the fuel hose in his hand (YOU NEVER LET SOMEONE
DO
IT
FOR YOU) sees them!
Sent: Thursday, August 25, 2005 10:59 PM
Subject: RE: Filler neck install
bransom
Post by bransom » Sat Feb 18, 2012 10:58 am
I found VansAircraft also has them in the 8-32 size, which I think is what
I'm after -- am looking at using these for screwing on cover plates on the
wing.
Also, on anchor nuts (AN3) you've recommended for the flaperon hinges -- are
those the all steel kind or the more expensive fibernut kind? I've got some
of the all steel and they are a lock type, but no fiber/plastic. Maybe as
long as it's locking it doesn't matter, but I'd rather ask than bury
something inside the wing that I shouldn't have.
Thanks again -- hate to be putting more crap in your inbox. :)
-Ben
get time.
Jesse,
at
rivet
-Ben/496R
like
DO
Ben...the one lug anchors I have been using and selling are VERY old stock.
They have a very significant thread depth and are all metal, fixed anchor
nut (one piece to be exact and not the cheap style staked)
Sent: Friday, August 26, 2005 5:54 PM
Subject: RE: Counter Sunk Anchor nuts
wing.
are
some
-Ben
get time.
Jesse,
look
at
rivet
-Ben/496R
not
like
SOMEONE
DO
John Kramer
Post by John Kramer » Sat Feb 18, 2012 10:58 am
Wayne sent me a set and they are a much more serious fastener than anything
I've seen over at AirParts.
John...369R
wing.
are
some
-Ben
get time.
look
at
rivet
not
like
SOMEONE
DO
Jesse Jenks
Post by Jesse Jenks » Sat Feb 18, 2012 10:58 am
Ben,
You should make sure the ones from Vans have dimpled rivet holes rather than
being dimpled to accept a countersunk machine screw. I made that mistake.
Jesse
Subject: Re: Counter Sunk Anchor nuts
Date: Sun, 28 Aug 2005 01:21:28 -0400
what
wing.
are
some
as
-Ben
C/S
if
get time.
look
at
look.
3/32
rivet
not
from
also
like
SOMEONE
DO
Jesse Jenks
I agree, Waynes' nuts are the best!
I decided to use drilled head bolts with safety wire for the flaperon hinge
brackets to be sure they stay in.
Jesse
Date: Sun, 28 Aug 2005 01:45:29 -0500
John...369R
stock.
what
wing.
are
got
some
Maybe as
-Ben
C/S
if
look
look.
3/32
bit
still
not
from
also
SOMEONE
