engine removal on FOKM
Posted: Sat Feb 18, 2012 1:51 pm
The supports for the lower engine mount attach points must be removed
and replaced. To be able to do this and still move the airplane around,
it appears I need to take the engine off.
I don't have an engine stand but do have an I-Beam mounted sliding
vertical lift which I use for lifting stuff. To avoid tying up the hoist
I plan to sling a chain around the beam at one end and hang the engine
from that while I work on the plane.
Three questions:
1. Is it safe to sling the engine from the hoop mounted on the top of
the engine? It looks like that is what its for.
2. I have the metal cowling with only the nose area made of fibreglass.
I see no particular reason to remove the prop/spinner/nosebowl from the
engine when I sling it. Any problem with this?
3. Removal of the engine can be by removing the bolts at the shock
mounts or presumably removing the bolts holding the mount to the
firewall. I would guess the shock mounts would be the normal choice but
is that correct?
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
wrightdg@davincibb.net
Three questions:
is that correct?
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
