drilling out rivits
Posted: Sat Feb 18, 2012 1:51 pm
by wrightdg
I took a look thru the archives and couldn't find anything on optimimum
sizes for bits for drilling out blind rivits. It seems to me that if one
built an airplane one would probably quickly discover the best way to do
so but its not obvious if one has not built yet.
My first guess would be a drill bit the same size as the hole the rivit
was set in. On the other hand that might leave some meat as the bit
might not center exactly. Others might try significantly larger bits
based on other arguments. Hopefully I don't start some sort of religious
argument with this novice query.
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
wrightdg@davincibb.net
drilling out rivits
by bransom
Garry,
I've only drilled out a few (knock on wood). I like to use the same size
drill (#30). I find practically no tendency for it to wander off center till
it readches the mandrel, which is a good place to stop drilling! At that
point I use a snap punch to pop the mandrel out the bottem -- it is just the
right amount of small force applied suddenly to do the trick. Hole is left
pretty as ever.
BTW Gerry, C-FISH looks awesome. Way to go!
-Ben
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
drilling out rivits
by wrightdg
Thanks Ben. Hopefully my experience will be limited to a few thousand on
this job. Cheers.
On Sun, 2005-14-08 at 20:18 -0800, bransom@dcsol.com wrote:
Garry,
pretty as ever.
-Ben
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
drilling out rivits
by Drew Dalgleish
Hi Garry I've drilled out more than a few rivets and what I have found is
that if you drill too deep so that the drill bit touches the mandrel the
bit will wander and leave you with an oversized hole. To get around that I
used to punch out the mandrel before drilling the rivet but what I find
works best now is to just drill the head part way then use a hammer and a
wood chisel to knock the head off flush with the metal. after that it's
relatively easy to punch out the rivet bodies or if the back side is
accesable I grab the rivet bodies with a pair of side cutting pliers and
just pull them out. Are you planning to repair your plane yourself?
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
drilling out rivits
by wrightdg
Hi Drew,
I will be doing as much as I can under the tutelage of an AME. I'm
hoping to develop at least some of the skills one gets in building the
airplane. Your method with the wood chisel will work well if the chisel
doesn't damage anything you want to retain. There will be more queries
of a similar nature as I go along. Thanks for the response.
Garry
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
drilling out rivits
by rognal
Garry,
What I learned from this list 5+ years ago when I started R687 was to use a
pin punch to punch out the mandrel, then use a 1/8" drill bit to drill off
the head, then a pin punch to pop out the rivet barrel.
The 1/8" drill bit is slightly smaller than the original rivet hole (talking
#30 rivet hole) and if you go slow when drilling the rivet head, the head
will usually just twist off before the 1/8" drill bit enters the original
hole. If it doesn't spin off and it looks like the bit is about to enter the
original hole I will stop and use a soft faced punch and tap the edge of the
rivet head. I've also used a small block of wood instead of the soft faced
punch.
This procedure has worked for me and the drill never enters the original
rivet hole.
Hope this helps.
Roger Hoffman 687R
Eugene, OR USA!
drilling out rivits
by wrightdg
Thanks Roger. I'll try that too.
On Mon, 2005-15-08 at 10:51 -0800, rognal@dcsol.com wrote:
Garry,
punch.
rivet hole.
Hope this helps.
Roger Hoffman 687R
Eugene, OR USA!
drilling out rivits
by Dave Ricker
I'll agree except that you may have to pop the mandrel back again after you drill
down to it. Pretty easy after you get some practice...........
Garry,
pretty as ever.
-Ben
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
David A. Ricker
Fall River, Nova Scotia
Canada
drilling out rivits
by carol and murray cherkas
Garry:
Roger and company covered all the basis.
It's not to hard.
Murray
To: "rebel builders" <rebel-builders@dcsol.com>
Sent: Monday, August 15, 2005 3:07 PM
Subject: Re: drilling out rivits
Garry,
off
(talking
faced
punch.
rivet hole.
Hope this helps.
Roger Hoffman 687R
Eugene, OR USA!
drilling out rivits
by Ken
FWIW I use 7/64th or 1/64 less than 1/8. I then break the head off by
inserting the back end of another 7/64 bit into the rivet head. Some
rivets require driving the mandrel back a bit with an automatic punch or
squeezing the back of the rivet with side cutters or end nippers to do
the same. End nippers work best if you have the room. That lets you
drill deep enough to break the head off. I have removed about 4000 of
the little devils in this manner without enlarging the holes.
For stainless drill at slow speed and I use a 1/8 cobalt bit. If not
using cobalt, a drop of oil helps keep the bit from overheating and dulling.
drilling out rivits
by Drew Dalgleish
Good to hear you're doing the work Garry I'm sure you'll enjoy the process.
I forgot to mention that you should slightly round off the corners of your
wood chisel to keep them from scratching.
At 12:06 PM 8/15/2005 -0600, you wrote:
Hi Drew,
Garry
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
drilling out rivits
by wrightdg
Drew, Dave, Murray,
Thanks for your comments. I think we have covered the waterfront and
have some really good ideas on rivit removal. If I can't do it with this
knowledge and idea set I should be grounded permanently. Cheers.
Hi Drew,
Garry
At 09:44 PM 8/14/2005 -0600, you wrote: Drew
drilling out rivits
by wrightdg
Thanks Ken. I'm on the way to getting a snap-punch in the am along with
other stuff. Should be find. Thanks again.
drilling out rivits
Posted: Sat Feb 18, 2012 1:52 pm
# 30 drill bit right down the mandrel hole. In heavier sections, or if you
can back up the sheet, you can use a small punch held with visgrips and a
quick tap to loosen the mandrel.
I have drilled out well over 25000 rivets during repairs and rebuilds. I
have only had to upsize 5 or 6 holes to 15's from 14's and if I remember
right 2 had to go to 16's due to sloppy drilling and rivet spin.
Sent: Sunday, August 14, 2005 11:44 PM
Subject: drilling out rivits
Garry Wright
R-068 C-FOKM Amphib
403 931 1573
