Fuel tubing
Jesse Jenks
Fuel tubing
Post by Jesse Jenks » Sat Feb 18, 2012 10:47 am
I plan to use aluminum fuel tubing throughout my Rebel. What size and type
is best? 1/4 or 3/8 I would guess. ACS has a few different alloys of tubing.
Is the 3003-0 "Versatube" strong enough, or should I use 5052-0, or 6061-0,
0r 6061-T6? Bending for corners will be an issue as well.
Jesse
Scott Aldrich
Fuel tubing
Post by Scott Aldrich » Sat Feb 18, 2012 10:47 am
Most common that I know of is 3/8th and the 3003 is plenty strong for fuel
lines, also easier to bend. I have seen them made with all 5052 but I don't
think it is necessary.
FWIW
Scott
Jenks
Sent: Monday, August 01, 2005 11:19 AM
Subject: Fuel tubing
Jesse
Scott Aldrich
Fuel tubing
I would add that I like the 5052 for long straight runs just because it
comes straight and looks nice while the 3003 seems to come rolled.
Jenks
Jesse
Jesse Jenks
Fuel tubing
Thank you Scott.
Subject: RE: Fuel tubing
Date: Mon, 1 Aug 2005 13:42:05 -0600
don't
FWIW
Scott
Jenks
tubing.
Jesse
Scott Aldrich
Fuel tubing
Hopefully someone else will confirm that - when they all get home from
Oshkosh.
Jenks
Sent: Monday, August 01, 2005 1:46 PM
Thank you Scott.
don't
FWIW
Scott
Jenks
tubing.
Jesse
rognal
Fuel tubing
Post by rognal » Sat Feb 18, 2012 10:47 am
Jesse,
Murphy supplied straight lengths of 5052-0 tubing, of 3/8ths inch OD, for the
fuel lines in my kit. I purchased some 3/8ths inch 3003-0 'Versatube' for the
more complicated runs. The 3003-0 is shipped in a coil from ACS and is much
easier to shape/form. I know of a flying RV at my home airport that the
builder used nothing but 3003-0 for his fuel lines. I think it is a pretty
common practice.
Roger Hoffman #687R
Eugene, OR USA!
Jesse Jenks
Fuel tubing
Thanks again Scott and Roger,
Roger, is your Rebel flying yet? I should come up and have a look. I could
waste a lot of your time asking questions.
Jesse
Subject: Re: Fuel tubing
Date: Mon, 01 Aug 2005 18:36:05 -0800
Jesse,
common practice.
Roger Hoffman #687R
Eugene, OR USA!
