Hi,
The seatbelt attach brackets mounted to the sidesills are called out
just ahead of station bulkhead 6, so that puts it between 5 and 6. This
seems to far ahead to me and with no seats in place I can't verify. Can
anyone tell me if it works there or how about a measurement from the
door post or hinge to the belt mounting bolt hole.
Also are there any tried and true measurements for the seat rails. I
would like to put them in and then finalize the floor. I don't plan on
burying anything under it.
Mike Betti
771E
Seatbelts
Seatbelts
Hi Mike !
The best way to position the seat rails is to mount the seat bottom
onto the rails ! That way you know the spacing will fit ! :-)
Hi,
Mike Betti
771E
