spring gear: insert
Posted: Fri Feb 17, 2012 8:27 pm
And Lonnie?
Could you send me some pics privately of those gussets, etc? I've got a brand new 17 gig hard drive I want filled ;-)
Thanks again,
Dan
I had to shape the outer ends of my inserts to match the shape of the =
corner wrap. I did it on the belt sander. I had saved the corner =
pieces that were cut off the front carrythrough so I used them as =
spacers between the insert and some gussets I made. I added stainless =
steel gussets to the vertical sides of the carrythroughs. They are a bit =
longer than the distance between the inner and outer bolts. The bolts =
now go through the gusset, then the two carrythroughs, and the gusset on =
the far side. You can use Alum. for the gussets. I sent pictures to =
Mike Davis but I have not seen them on the site pictures.
Thanks again,
Dan
