Covering exhaust with tape.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 1:38 pm
Not so sure it's the tape either Bob. I stuck my neck out on the Supercub
site and got machine gunned. Guys have been running it on their planes for
many years with no detrimental effects to stainless exhausts and tell me
they wouldn't run a plain steel one anyhow. The exhaust that was on Mike
Davy's Rebel was plain steel..one of the first HP exhausts from MAM I
believe and it was just about toast at 32 hours total time and it was stored
in a hangar. Makes me wonder if the tape is the culprit!
Sent: Tuesday, June 07, 2005 10:54 PM
Subject: Re: Rebel - High temps
** Check your subject, does it still reflect the message? **
Hi Drew !
That Rebel was stored in a hangar - albeit in a very foggy
area -
Newfoundland ! ;-) :-) Maybe a little more humidity than your
area ...... It was just a reminder to peek under the tape now & then !
Sounds like you're having good results. Some builders have had
great results by having the insides of the exhaust pipes ceramic
coated - lots of automotive places to do this at reasonable cost...
On Tuesday 07 June 2005 10:21 pm, Drew Dalgleish wrote:
Hi Bob
Thanks for the reminder. I know you don't like the stuff but I've been
flying with the tape on for over 6 years now. Neither the antique
tri-pacer
crossover ehaust or the mild steel extension pipes were showing any
signs
of deterioration other than surface rust on the mild steel last fall
when I
checked. Were the ones that corroded stored outside?
Hi Drew !
Be very careful of that ceramic tape - especially if the exhaust
is not stainless steel !! There have been many reports of moisture
trapped in the tape causing hidden corrosion - one Rebel landed
with exhaust flames blowing out on the gascolator because the
whole pipe was eaten away under the tape !!
