Spring gear mount Elite
Posted: Sat Feb 18, 2012 1:35 pm
Help...........,
I messed up the spring gear mounting and looking for advice. First when
I drilled the top of the fus5 to 7/16 for the crush spacers, I had the 2
doubler plates on top and drilled through them also. So I made the crush
spacers that much longer to compensate. I don't know what kind of down
force there is trying to pull that saddle bolt penny washer down
through. Think this is ok or maybe add some sort of doubler on top of
the present 2?
On the same subject I also screwed up the alignment of that same 7/16
hole. It appears that the top doublers didn't give me such a good
template drilling and now the saddle bolts and crush spacers are not
straight with regards to the bottom holes! I was thinking maybe adjust
the top of the hole to make the spacer true in the 2" square tube and
then tig weld the old part of the hole closed, maybe even weld to the
crush spacer.
Any advice welcome and thanks in advance as usual.
Mike Betti
771E
the present 2?
crush spacer.
Mike Betti
771E
