just up loaded pdf's of my door layout with dimensions for cut out, should
mention that when friend cecil shaw did this design this winter he still had
to cut small oval cutout in the panel that overlaps the bottom of the door
frame, but rest worked pretty good
also not you need to get aluminum tube to slide inside the door frame to
join the top and bottom halves together and leave 12" of overlap each side
to put lots of rivets in it to make the join strong, hope this makes sense
mike#007
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of Bob
Andrews
Sent: Thursday, June 02, 2005 8:44 AM
To:
rebel-builders@dcsol.com
Subject: RE: Elite doors
Hi Mike,
Look forward to seeing them. To get the door demention changes at the
forward lower corners, I'm temporarily installing one of the wings and wing
strut. One solution to the strut clearance issue is to do what Sam and
Sandy did ... The Archer Elite has gull wing doors, and they hinged the
lower front corner section of the door so that it can clear the wing strut
... and it works well. My plan is to gusset the fuselage opening at that
corner and remove the same area from the door.
Bob 612e
Jones, Michael
Sent: Thursday, June 02, 2005 4:58 AM
To: '
rebel-builders@dcsol.com'
hi mike
whay are you looking for, gull wing doors ?
i have drawings and all part numbers for ordering
will try to repost the pics and some new asap
mike#007
Mike Betti
Sent: Wednesday, June 01, 2005 8:11 PM
To:
Subject: Re: Elite doors
I can't find any pics in the arcives. Looks like Mike 007 had some in the
rebel files but they aren't there anymore. Mike do you still have those door
pics.
Mike Betti
oifa@irishfield.on.ca>
To: <
rebel-builders@dcsol.com>
Sent: Tuesday, May 31, 2005 9:24 PM
Look in the Rebel section. Sure there are some pics there of gullwing
doors.
My doors swing both ways. Normal front hinged door and up lifting window,
or
bolt the two sections together, remove the front hinge pin and they become
gullwings. Guess I might finally get around to using them that way in the
next few weeks if I ever get those floats on!
mbetti@up.net>
To: <
Sent: Tuesday, May 31, 2005 10:19 PM
That's what I would like, anybody have any pics of a finished product?
Mike Betti
robert@montanasky.us>
To: <
Sent: Tuesday, May 31, 2005 5:39 PM
Mike,
Plan on making them seaplane doors .... both doors fully windowed and
hinged
along the top. The forward bottom corner will be removed from the door
List archives located at:
https://www.dcsol.com/login
List administrator:
List administrator:
HATCH immediately via mailto:
MailAdmin@hatch.ca.
List administrator:
List administrator:
MailAdmin@hatch.ca.
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
