thanks for the replies on the 3/32" rivets.
One more quick question....
What type of quick connectors is used on the elevator trim and rudder trim
servo wires (to make installation and disassembly easier). And what type of
connectors are used to join the wires together from the supplied 30' spool to
the 5" short pieces on the servo.
Thanks.
Bob Scheuber
moose 191
QUICK CONNECT
QUICK CONNECT
I went thru hoops finding a nice connector when I did mine, BUT you know the
most dependable way is solder and shrink tube over top. If you have to
dissassemble... one snip and it's apart. Re-assembly took me all of 7
minutes today on CYP.
Sent: Tuesday, May 31, 2005 3:06 PM
Subject: QUICK CONNECT
ofthanks for the replies on the 3/32" rivets.
toconnectors are used to join the wires together from the supplied 30' spool
Thanks.
Bob Scheuber
moose 191
