Your tires?
Ted Waltman
Your tires?
Post by Ted Waltman » Sat Feb 18, 2012 1:35 pm
Larry,
Question on your below email. I thought the middle #, the 10 in your
below email, refers to the hub width (while the 26 would be diameter and
the 6 the ply). You don't have a 10" hub do you?
I looked through all the displays in the recent Trade-a-Plane and I
don't see any size listed that you report. I'm interested--very
interseted--in a larger tire, especially one that would just fit on the
existing MAM hub.
Any input is MUCH appreciated Larry. Guess I owe you lunch on the 16th.
It's getting close!
Thank you,
Skytrucks@aol.com
Sent: Saturday, May 28, 2005 9:17 PM
Subject: Re: Gar-Aero tires/wheels for the Moose?
Ted;
I would NOT use the Gar-Aero tires and adaptors. I have the, I
think
26x 10x 6 tires on my Super Rebel, they fit any 6 inch wheel ( Murphy).
They
work great and are light.
I will look forward to meeting you on your trip North in the
middle
of the month.
Larry
Luckinbill
SR 013 and
SR 117 Moose
Skytrucks
Your tires?
Post by Skytrucks » Sat Feb 18, 2012 1:35 pm
Ted;
My tires are 26--10.50--6 Goodyear Part no 260K61-1. They go on any
standard 6" wheel. I just checked at desser.com, they are $495 each with tube.
They are great, I also have a set on my experimental Artic Tern. Good Luck!
Larry Luckinbill
