hi all
so how do i paint my instrument panel, primers, flat coat, etc
mike#007
painting panels
painting panels
Hi Mike,
I just painted my panel last weekend. I used all Poly Fiber products. #310
cleaner, Aluma-Dyne E-2300 Conversion Coating, EP-420/430 Epoxy Primer, and
their regular enamel as the color coat. Applied the conversion coating with
fine scotchbrite pad to scuff the surface at the same time, per Poly Fibers
instructions.
Roger Hoffman #687R
Eugene, OR USA!
instructions.
Roger Hoffman #687R
Eugene, OR USA!
