Bolt fit
Jesse Jenks
Bolt fit
I drilled and reamed the strut attach fittings to the spar of my right wing
today, but I'm not happy with the fit of the bolts. They drop into the holes
without a push and couple have some side to side play Should I be worried
about this? I will look for a smaller reamer (mine is .249), but now I have
these 4 loose holes. I remember reading about oversize bolts. Do they go a
few thou bigger? If so, that would make for a tight fit. Or I could use 5/16
bolts I guess?
My 3/16 reamer makes for a closer fit with the 3/16 bolts. This is the first
time I've used the 1/4, and it happens to be a rather critical area
unfortunately.
Jesse
bolts I guess?
unfortunately.
Jesse
Bolt fit
Yes AN174- close tolerance are under a dollar from Aircraft Spruce. Or
even just try another bolt from a different source as they do vary by a
thou or two. Since you already used an undersize reamer it could be that
you just happen to have some small diameter bolts.
Al Paxhia wrote:
A thought is to check out using close tolerance bolts. They are not
inexpensive but may be the simplest solution. If you can go up one size it
is also easy to have a tool shop grind an undersize reamer, to fit your
bolts. A custom reamers cost about $40, this is what I have done.
Al
Moose, N526AP
steve whitenect
Bolt fit
Just talked to Gil Tessier this afternoon and someone here in the Edmonton
area recently ran into the same thing. Used a reamer and one of the four
attachment bolt holes was loose. Discovered a discrepency in the an bolts.
Steve W.
Steve W.
Subject: Re: Bolt fit
Date: Tue, 17 May 2005 17:07:19 -0400
Al Paxhia wrote:
itA thought is to check out using close tolerance bolts. They are not
inexpensive but may be the simplest solution. If you can go up one sizeis also easy to have a tool shop grind an undersize reamer, to fit your
Al
Moose, N526AP
Jesse Jenks
Bolt fit
Thanks for the replies guys,
I think for the other wing I will find a way to use the drill press,
probably put it on the floor and block up the spar. I do have a drill bar
with bushings, but didn't think it would be good to run the reamer through
it. I didn't think about pulling it through from the back. Will they cut
like that? Anyway, for now I need to figure out how to solve my existing
problem.
I am looking at AN-174 in a reference book from Genuine Aircraft Hardware
Co. They show the max diameter as .2492, & min Dia .2487. That's not
oversized, but slightly undersized. I put the micrometer on a few of my
bolts, they are all about .2475 ish, so I don't think the close tolerance
bolts would do the trick if they are only say 1.5 thou bigger. I guess it's
worth a try though. Also it seems like they only come in the drilled shank,
or drilled head and shank variety? I guess that's OK though? I will send an
email to MAM about going to 5/16 bolts, but the last question took Robin a
month to respond to.
Just my way of saying that you guys on this list are really a great asset!
Thanks again.
Jesse
problem.
Thanks again.
Jesse
Bolt fit
Drilled shank or head should not make any difference especially since
these are loaded in shear.
These bolts should ideally be snug but I'm sure many aircraft were not
even reamed and most were drilled and/or reamed by hand with no guide so
perhaps one doesn't need to be overly critical??
I've never heard of pulling a reamer through backwards. The front has a
slight taper (maybe 5 thou or so) specifically to start into the hole.
If one wants to use a block why not use it on the front side? A drill
press definately works nicely if available.
problem.
Thanks again.
Jesse
bransom
Bolt fit
Is a block guide something you just make, i.e. a block with the right size
hole in it from a drill press? Sounds like a good way to go to ensure the
reamer or drill starts in perpendular to a surface. But I would think for
thicker parts you'd want to let the reamer follow the hole instead of the
block guide. Isn't this a case where just being sure to move up to final
size in steps should do the trick -- that being with reamer for the final
step and measuring bolt and reamed size on scrap beforehand?
-Ben
PS: Good luck with it Jesse -- sounds like a frustrating experience.
-Ben
giveHi Jesse
Did the same thing with my Christavia and ordered the oversized bolts at
about $25. us each. I can get the old paperwork out if you like. I believe
they are .010" oversized which will probably have you finding an adjustable
reamer and bring the holes up to the bolt size. Murphy shud be able to
anyou their blessing to go the next size up. To bad there wasn't any metric
1/4 "bolts available. You'd probably find one a little bit larger than the
whereat a fraction of the price. I used a block guide on all other fittings
I could fit one to ensure alignment.. I believe the safest way to drill
these fittings is to mount a block guide on one side and pull the reamer
thru from the opposite side. You have to use a chucking reamer. That way
you can keep the shaft of the reamer centered in the block hole as you pull
it thru. Ensure you have a quality reamer and measure the hole it makes
before use. There are alot of what are called hole cleaners out there and
are passed on for reamers.
Steve W.
Rebel #637
Subject: Bolt fit
Date: Mon, 16 May 2005 19:21:59 -0700
holes
5/16
bolts I guess?
first
unfortunately.
Jesse
steve whitenect
Bolt fit
Hi Jesse
reamer and bring the holes up to the bolt size. Murphy shud be able to give
you their blessing to go the next size up. To bad there wasn't any metric an
bolts available. You'd probably find one a little bit larger than the 1/4 "
at a fraction of the price. I used a block guide on all other fittings where
Steve W.
Rebel #637
Steve W.
Rebel #637
Subject: Bolt fit
holes
5/16
bolts I guess?
first
unfortunately.
Jesse
Al Paxhia
Bolt fit
Al
Moose, N526AP
Sent: Tuesday, May 17, 2005 11:52 AM
Subject: RE: Bolt fit
Al
Moose, N526AP
Hi Jesse
adjustable
give
an
where
pull
Steve W.
Rebel #637
Subject: Bolt fit
wing
holes
have
5/16
bolts I guess?
first
unfortunately.
Jesse
Schmucker, Del
Bolt fit
I heard quite a bit about using reamers to drill critical holes. On my
Rebel I never used a reamer; all holes were drilled with drill bits. On
critical holes like the struts etc. I always use new or virtually new
bits that were still in excellent shape. I always step drilled the
holes and used a drill press. My bolts always fit well. If I had the
odd one that was tight I would try another bolt or just drill again and
let the bit just run in the hole and it would always take off just that
extra. On bolts like the struts I also always put the bolts in wet. I
saw no reason to dismantle the strut sections.
Thank you,
Del Schmucker
Information Systems Manager
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
bransom@dcsol.com
Sent: Wednesday, May 18, 2005 12:22 PM
size
for
final
final
-Ben
give
an
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
bransom@dcsol.com
size
for
final
final
-Ben
atHi Jesse
believeabout $25. us each. I can get the old paperwork out if you like. I
adjustablethey are .010" oversized which will probably have you finding an
toreamer and bring the holes up to the bolt size. Murphy shud be able
give
metricyou their blessing to go the next size up. To bad there wasn't any
an
drillI could fit one to ensure alignment.. I believe the safest way to
reamerthese fittings is to mount a block guide on one side and pull the
waythru from the opposite side. You have to use a chucking reamer. That
pullyou can keep the shaft of the reamer centered in the block hole as you
makesit thru. Ensure you have a quality reamer and measure the hole it
andbefore use. There are alot of what are called hole cleaners out there
right wingare passed on for reamers.
Steve W.
Rebel #637
Subject: Bolt fit
thetoday, but I'm not happy with the fit of the bolts. They drop into
worriedholes
I haveabout this? I will look for a smaller reamer (mine is .249), but now
go athese 4 loose holes. I remember reading about oversize bolts. Do they
usefew thou bigger? If so, that would make for a tight fit. Or I could
the5/16
bolts I guess?
first
unfortunately.
Jesse
steve whitenect
Bolt fit
Jesse
A good chucking reamer will cut from the top of the flutes as well as the
bottom
Steve W.
bottom
Steve W.
Subject: Bolt fit
Date: Tue, 17 May 2005 19:03:16 -0700
problem.
Thanks again.
Jesse
steve whitenect
Bolt fit
Hi Ben
A block guide is just that. A square 1" block of steel what ever length you
need to clamp it to whatever. For letting the reamer follow the hole then
you want what is called a spiral fluted reamer which has a definate taper up
to the finish size and is usually turner by hand. Don't confuse this with a
tapered pin reamer. Two different animals.
Steve W.
Steve W.
Date: Wed, 18 May 2005 09:21:59 -0800
-Ben
believeHi Jesse
about $25. us each. I can get the old paperwork out if you like. Iadjustablethey are .010" oversized which will probably have you finding angivereamer and bring the holes up to the bolt size. Murphy shud be able tometricyou their blessing to go the next size up. To bad there wasn't any
an1/4 "bolts available. You'd probably find one a little bit larger than thewhereat a fraction of the price. I used a block guide on all other fittingswayI could fit one to ensure alignment.. I believe the safest way to drill
thru from the opposite side. You have to use a chucking reamer. Thatpullyou can keep the shaft of the reamer centered in the block hole as youandit thru. Ensure you have a quality reamer and measure the hole it makes
before use. There are alot of what are called hole cleaners out therewingare passed on for reamers.
Steve W.
Rebel #637
Subject: Bolt fit
I drilled and reamed the strut attach fittings to the spar of my rightworriedtoday, but I'm not happy with the fit of the bolts. They drop into the
holes
without a push and couple have some side to side play Should I behaveabout this? I will look for a smaller reamer (mine is .249), but now Igo athese 4 loose holes. I remember reading about oversize bolts. Do theyfew thou bigger? If so, that would make for a tight fit. Or I could use
5/16
bolts I guess?
first
unfortunately.
Jesse
