problem with e-mail
problem with e-mail
Post by Mike Davis » Sat Feb 18, 2012 10:31 am
I imagine that Mark with Metal Crafters is a valid member of the builders
group, but I continuously get these errors for this address...
The message can not be sent to recipient:
mark@metalcrafters.ph
Reason: A transaction failure was reported by remote server:
"550 <mark@metalcrafters.ph>, Recipient unknown"
I've removed this address from the list a couple of times after days of
getting one of these bounce messages for every message posted to the list,
so I can only assume that Mark is re-subscribing. Just wanted to let you
know Mark what the problem is. Do you have another e-mail address you could
use? You could always setup your own account on the archive site if you
haven't already, then configure you mail client to pull mail from
mail.dcsol.com using the same username and password you setup on the archive
site.
