FLAT TIRE
Jones, Michael
FLAT TIRE
Post by Jones, Michael » Sat Feb 18, 2012 10:28 am
HI ALL
i got flat tire, dam it, just sitting in my garage a tire has gone flat,
where can we get rebel tubes ??
mike#007
FLAT TIRE
Post by Bob Patterson » Sat Feb 18, 2012 10:28 am
Hi Mike !
You can always order from Murphy ! ;-)
If you have the fat 800 x 6's, I've heard that these tubes are
available at Wally Mart - the important thing is the angle
bend on the valve stem..... (ask for golf cart tubes ! ;-) )
If you have the regular aviation tires, you can get those
tubes from Leavens or any of the usual $uspect$ ....
It is a good idea to get TWO tubes - I try to have one spare
with me in the airplane, as they can be hard to find in
"the middle of nowhere" !
On Friday 29 April 2005 09:07 am, Jones, Michael wrote:
HI ALL
flat,
mike#007
Robert and Olga Johnson
FLAT TIRE
Post by Robert and Olga Johnson » Sat Feb 18, 2012 10:28 am
Hi Mike: I experienced a similar thing with my Rebel and after patching the
tube (twice with bicycle tube repair kit) I finally found a rough internal
tube label that was wearing on the tube. After removal of the label I have
had no problems in over two years. When you disassemble to repair (patch)
inspect the inside of your tire carefully. Bob J
To: "Rebel-Builders EMIAL (E-mail)" <rebel-builders@dcsol.com>
Sent: Friday, April 29, 2005 9:07 AM
Subject: FLAT TIRE
HI ALL
mike#007
