Amphib main gear
ray.mason
Amphib main gear
Post by ray.mason » Sat Feb 18, 2012 10:27 am
I have the old style pucks (called rebound Disk by MAM) on my Amphib landing
gear and wasn't happy with the shock absorbing preformance of them. I bought
a set of the new bigger style ones from MAM (total cost 288.70 ouch)which
they short shipped 2 and went to install them. After taking the old ones off
something wasn't quite right and it seems like I need part # FL 265 (spacer).
Can anyone post a pic of the parts list and diagram for the landing gear or
email me direct. I started taking the other side apart and found that the
shock arm was siezed, no wonder I wasn't getting any shock absobtion! After a
few good bangs on a wood stick it still seized and it looks like I might have
to cut the bolts head off to get them out unless someone has a better
suggestion. Also I heard that MAM was providing these pucks for free if you
had the old style, can anyone confirm this?
Ray
Rebflyer
Amphib main gear
Post by Rebflyer » Sat Feb 18, 2012 10:27 am
HI Ray,
I had the same old style rebound pucks in my 1800's and after 3 yrs of
replacing the ones that shifted out of place I ordered the new ones. FL/260.
NOT free. I did use the spacers between the disc's, but not on the end's. I
have 6 or 7 landings on the new style with no shifting and they do feel
slightly better on the ground. I did preload the system with that stack up too.
Speaking of stack up's, we now have about 5" of snow on the ground as of
this am with more to come. This is after 3 weeks of 60f+ weather with an 83
degree stuck in a week ago.
SIGH, my zipcode is still Michigan.
Curt N97MR
Amphib main gear
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:27 am
Better you than me Curt !!! LOL I"ve got to haul an airplane 60 miles to
paint this afternoon! We've had heavy rain for two days, but luckily (till I
get that plane loaded anyhow) it's stayed warm enough to keep it liquid.
Calling for snow late this afternoon and I can't drop the plane off until
7:30pm %(*$^^(!!
As for the gear rubbers......if anyone doesn't need those old ones anymore
I'm more than willing to take what you have off your hands. I like the old
rubbers in combination with the Bellville washers I use to retain them and
add to the shock load value. Not sure yet what my prebuilts have in them as
I can't pull the wheel out far enough to look at them sitting in the crate
holders. MAM plumbed them cylinder to cylinder, with fluid in the lines so
they are hydraulically locked in position..along with the brake caliper
jammed against the brake line retainer strip cause it's in the wrong
place... amongst a few other boo boos... like bottom skin not clearanced in
the right place so the trailing arms can come down etc. Going to be a bit
more work to get these onto an aircraft than I thought, but not as much as
having to build from scratch :O)!
Wayne O'Shea
1516 Alvin Williams Rd
Penetang, Ontario
L9M-2C1
Sent: Sunday, April 24, 2005 11:42 AM
Subject: Re: Amphib main gear
HI Ray,
FL/260.
up too.
83
Curt N97MR
Amphib main gear
Post by Walter Klatt » Sat Feb 18, 2012 10:27 am
Have to rub it in when I can, but went to the lake yesterday, and
it was like mid summer with shorts, tee shirt and all my vents
open in the plane to keep cool. Temps up the valley at the Hope
airport, which is not far from Harrison Lake hit 28 C/82 F
yesterday. On the way home, though, had to skirt around a mild
thunderstorm, and my wife was with me, so she wasn't too happy
with that.
I am using the big blue pucks which I switched to before I even
flew on my amphibs. I think these were the Elite nose gear ones.
I believe they are the same dimension as the new yellow ones, but
not sure about the stiffness. Mine are pretty stiff, but that's
how I like them, with no chance of bottoming out.
Sent: Sunday, April 24, 2005 9:08 AM
to keep it liquid.
the plane off until
7:30pm %(*$^^(!!
the brake caliper
it's in the wrong
Wayne O'Shea
Penetang, Ontario
L9M-2C1
HI Ray,
FL/260.
up too.
83
Curt N97MR
Amphib main gear
Well Walter all that means is snow for you next week!!! We were 28*C last
Wednesday (after two+ weeks of sunshine) and sweating working in the hanger.
Back to reality and real April weather now!
Sent: Sunday, April 24, 2005 12:33 PM
Subject: RE: Amphib main gear
with that.
to keep it liquid.
the plane off until
7:30pm %(*$^^(!!
the brake caliper
it's in the wrong
Wayne O'Shea
Penetang, Ontario
L9M-2C1
HI Ray,
FL/260.
up too.
83
Curt N97MR
Amphib main gear
Yeah, I know the feeling. We had a ridiculously warm Feb here,
but then back to winter at the end of Mar and first half of Apr.
But I'll take it anytime we get it. Heading out right now for
some more flying.
Sent: Sunday, April 24, 2005 9:38 AM
yesterday, and
all my vents
at the Hope
around a mild
too happy
with that.
before I even
nose gear ones.
yellow ones, but
but that's
to keep it liquid.
the plane off until
7:30pm %(*$^^(!!
the brake caliper
it's in the wrong
Wayne O'Shea
Penetang, Ontario
L9M-2C1
1800's and after 3 yrs of ordered the new ones.
FL/260. but not on the end's.
I shifting and they do feel system with that stack
up too. snow on the ground as
83 -------------------------------------------------------
---------- https://www.dcsol.com/login?mode=HTML -------------------------------------------------------
