Britt,
Did you use the same servo and backing plates, gussets, horn etc. as in the
elevator? Did you by chance take any pictures as you were building? I read all
I could find on the search and could not find the answers to these questions.
Thanks again.
Bob SR191
On 4/22/2005 8:34 AM,
BRITT.REED@HILL.AF.MIL wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for
rebel-builders@dcsol.com; Fri, 22 Apr 2005 08:34:55 -0800
-> Received: from ofgate.hill.af.mil ([137.241.250.11]) EHLO=ofgate.hill.af.mil
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 640266171; Fri, 22 Apr 2005 08:34:53 -0800
-> Received: from AP-HILL-TM1.hill.afmc.ds.af.mil (ap-hill-tm1.hill.af.mil
[137.241.230.80])
-> by ofgate.hill.af.mil with SMTP id j3MGYufx028235
-> for <
rebel-builders@dcsol.com>; Fri, 22 Apr 2005 10:34:56 -0600 (MDT)
-> Received: from 137.241.230.90 by AP-HILL-TM1.hill.afmc.ds.af.mil (InterScan
E-Mail VirusWall NT); Fri, 22 Apr 2005 10:34:49 -0600
-> Received: by fskrsm10.hill.afmc.ds.af.mil with Internet Mail Service
(5.5.2657.72)
-> id <J23Y4HFF>; Fri, 22 Apr 2005 10:34:49 -0600
-> Message-ID:
5184FD9EA1B054469B326D38753DB8290D80FF@fskrsm37.hill.afmc.ds.af.mil>
-> From: Reed Britt Civ OO-ALC/MADE <
Britt.REED@HILL.af.mil>
-> To: "'
rebel-builders@dcsol.com'" <
-> Subject: RE: Rudder trim?
-> Date: Fri, 22 Apr 2005 10:34:47 -0600
-> X-Orig-MIME-Version: 1.0
-> X-Mailer: Internet Mail Service (5.5.2657.72)
-> X-Orig-Content-Type: text/plain
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Bob - If I remember right there is some good info back in the archives - I
-> talked to RC Allen (he laughs about the size of the elevator trim on the
-> 3500) and chose 1/2 a bay (added a rib in the midpoint) so it was about 6"
-> and 2" deep. To keep it up away from elevator interference I put mine in the
-> bay under the mid-hinge.
-> Britt SR194
-> -----Original Message-----
-> From:
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com] On Behalf Of
bscheube@dcsol.com
-> Sent: Friday, April 22, 2005 9:54 AM
-> To:
-> Subject: Re: Rudder trim?
-> Scott and Britt,
-> Since you guys added the trim is there a place I can get info on this
-> installation (i.e. parts list servo, piano hinge ribs) and also how did
-> you size the trim (use the same instructions as on the elevator?) thanks.
-> Bob SR191
-> On 4/22/2005 7:43 AM,
SA@MWUTAH.COM wrote to REBEL-BUILDERS:
-> -> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> -> for
rebel-builders@dcsol.com; Fri, 22 Apr 2005 07:44:34 -0800
-> -> Received: from mail.mwutah.com ([208.186.255.2]) EHLO=mail.mwutah.com
-> -> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> -> id 637245890; Fri, 22 Apr 2005 07:44:32 -0800
-> -> Received: from mail.mwutah.com (localhost [127.0.0.1])
-> -> by mail.mwutah.com (mwutah.com) with ESMTP id D4D55141496
-> -> for <
rebel-builders@dcsol.com>; Fri, 22 Apr 2005 09:43:03 -0600 (MDT)
-> -> Received: from 65.74.4.34
-> -> (SquirrelMail authenticated user sa);
-> -> by mail.mwutah.com with HTTP;
-> -> Fri, 22 Apr 2005 09:43:03 -0600 (MDT)
-> -> Message-ID: <31801.65.74.4.34.1114184583.squirrel@65.74.4.34>
-> -> In-Reply-To: <
1114181544@dcsol.com>
-> -> References: <
-> -> Date: Fri, 22 Apr 2005 09:43:03 -0600 (MDT)
-> -> Subject: Re: Rudder trim?
-> -> From:
sa@mwutah.com
-> -> To:
-> -> User-Agent: SquirrelMail/1.5.0
-> -> X-Orig-MIME-Version: 1.0
-> -> X-Orig-Content-Type: text/plain;charset=iso-8859-1
-> -> X-Priority: 3
-> -> Importance: Normal
-> -> X-Orig-Content-Transfer-Encoding: quoted-printable
-> -> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> -> After flying the M14 demonstrator without it, I added rudder trim also.
-> -> Scott
-> -> M/SR 174
-> -> > Hello all,
-> -> > I am getting ready to close up the rudder and had a question
-> -> > about rudder trim? Several Months ago Ted Waltman was nice enough to
-> -> > take me up in his Moose and allowed me to take alot of pictures!!(thank
-> -> s
-> -> > again Ted) anyway while going through my pictures I noticed the rudder
-> -> > trim on
-> -> > Teds plane and was wondering how many others have added this and if it
-> -> is
-> -> > worth it?? thanks.
-> -> > Bob Scheuber SR191.
-> -> > List archives located at:
https://www.dcsol.com/login?mode=HTML
-> -> > username "rebel" password "builder"
-> -> > Subscription services located at:
-> -> > List administrator:
-> List archives located at:
-> Subscription services located at:
-> List administrator:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
