mounting the vertical fin
Post by Mike Davis » Fri Feb 17, 2012 4:20 pm
Received: from JimsRebel@aol.com
by imo30.mx.aol.com (IMOv13.ems) id GWJJa08345
for <murphy-rebel@dcsol.com>; Sat, 28 Feb 1998 18:46:36 -0500 (EST)
Message-ID: <6758262c.34f8a1de@aol.com>
Date: Sat, 28 Feb 1998 18:46:36 EST
Mime-Version: 1.0
Subject: mounting the vertical fin
X-Mailer: AOL 3.0 for Windows 95 sub 49
Hi all ...
My question to all of you folks is did any of you have a gap between the
forward attach point of the vertial fin (the same one you move left or right
3/4 inch for engine offset ) and FUS-31/bulkhead doubler ... see figure 37
chapter 13 step 107... I have about a 1/4 inch gap. I first checked the
angle
of FUS-31 but found it matched the angle of the other bulkheads.... The
skin
for the fin is prepunched which set the forward and rear spar ( and attach
point ) at a set distance apart....... The horizontal bulkhead (fus- 31 ) ,
see fig 35, sets the fin at its position away from fus-36 ...... So the
choices are
#1, add a 1/4 spacer under the forward attach point of the fin ( where it
attaches with nine 3/16 rivets
#2, cut the tab of the aft end of the horizontal bulkhead , fus-31 , ( where
it attaches to the aft spar of the vertical fin with 3 rivets ) shorting it
1/4 inch and then add a piece of angle ,st-40 , for the three rivets to
attach
to the spar... This would also shorten the aircraft by 1/4 inch..
#3, Your idea goes here ....
Jim LePard rebel 254 ... JimsRebel@aol.com
Received: from computer (line-30.dryden.net [207.61.169.230]) by
server.dryden.net (8.7.5/8.7.3) with ESMTP id AAA18825 for
<murphy-rebel@dcsol.com>; Sun, 1 Mar 1998 00:35:37 -0600
Message-Id: <199803010635.AAA18825@server.dryden.net>
Subject: Re: mounting the vertical fin
Date: Sat, 28 Feb 1998 23:34:25 -0600
X-MSMail-Priority: Normal
X-Priority: 3
X-Mailer: Microsoft Internet Mail 4.70.1161
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Jim:
I had much the same problem I just added a spacer. You could probably do
the cutting and save 2-3 onces maybe. I think adding the spacer is easier.
When you do this your rivets will not reach so I used 4- 3/16 bolts(with
Murphy's approval).
Del
Date: Saturday, February 28, 1998 5:46 PM
Hi all ...
right
37
angle
skin
attach
choices are
where
it
attach
Received: from d.james (ba1p28.planeteer.com [204.50.144.61])
by toronto.planeteer.com (8.8.7/8.8.7) with ESMTP id UAA17336
for <murphy-rebel@dcsol.com>; Mon, 2 Mar 1998 20:20:15 -0500 (EST)
Message-ID: <34FB5B58.7A615C11@planeteer.com>
Date: Mon, 02 Mar 1998 20:22:32 -0500
X-Mailer: Mozilla 4.01 [en] (Win95; I)
MIME-Version: 1.0
X-Priority: 3 (Normal)
References: <6758262c.34f8a1de@aol.com>
X-Corel-MessageType: EMail
JimsRebel wrote:
Hi all ...
forward attach point of the vertial fin ...snip
Yes - I had this problem the first time I built my tail cone however I
had the pleasure of doing it again as the tail cone somehow moved. The
second time, in order to avoid this possible problem, I mounted the fin
while constructing the tail cone to ensure there was no gap. I pass
this on as a hint to those not yet at this stage.
David James, Rebel 228
