Rebel Door Plunger Assembly Question
Terry Dazey
Post by Terry Dazey » Sat Feb 18, 2012 10:24 am
Hello Again Rebel Group:
I have a question for you building Rebel 662 Door Plunger Assembly
I am not sure what the specifications of the (D-12) tube that goes into
the door latch plunger is (I have no D-12 in inventory). It looks like I
have two choices in my stock: 1/4 inch O.D. OR 3/16 O.D. (D-11)
material. See Chapter 21, Figure 23.3.10.
HOWEVER . . .
The 1/4 inch O.D. material will fit in the Delrin Plunger 1/4 inch wide
machined slot BUT has I.D. larger than the 1/8 inch rivet that is
suppose to hold it in place.
The 3/6 inch O.D. material is a bit loose in the Delrin Plunger machined
slot and has a smaller I.D. than the 1/8 inch rivet, consequently, if
this is what I should use, the I.D. will need to be drilled to #30 for
the rivet to fit.
Which tube material is correct to use?
Thanks in advance for any information.
Terry Dazey
Rebel 662
Sumner, Washington USA
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:24 am
It's just there to hold the spring back. Just reworked those on Howard's
doors last week and it's indeed 3/16 OD x 1/8ID. While the piece of tube is
still long run your #30 bit down the tube. Then make your slices and clean
them up enough to get the rivet in again.
To: "Murphy Group" <rebel-builders@dcsol.com>
Sent: Thursday, April 14, 2005 1:38 PM
Subject: Rebel Door Plunger Assembly Question
HOWEVER . . .
the rivet to fit.
Terry Dazey
Rebel 662
