Power flow exhaust:
Alvin and Glenys Adams
Power flow exhaust:
Post by Alvin and Glenys Adams » Sat Feb 18, 2012 1:24 pm
Thanks for information.Will scrap ideal off power flow.I do not want a noisy
aircraft either inside or outside.If i go with the speed cowl can i
practically install a exhaust with a muffler or do i have to go with tho
nose bowl cowling.
Regards: Alvin
From: "rebel-builders-d digest" <rebel-builders-d@dcsol.com>
To: <rebel-builders-d@dcsol.com>
Sent: Sunday, April 10, 2005 8:00 PM
Subject: DIGEST - rebel-builders-d
Digest of list: rebel-builders-d Total messages in digest: 21
1 Date : Sat, 9 Apr 2005 17:17:54 -0700 (PDT)
Subject: Re: float question and mooney with lyc 0-320
2 Date : Sat, 9 Apr 2005 21:06:55 -0400
3 Date : Sat, 9 Apr 2005 21:16:41 -0400
Subject: Epoxy primer
4 Date : Sat, 9 Apr 2005 18:30:24 -0700 (PDT)
Subject: Re: nose gear back-up/foldup tubes
5 Date : Sat, 9 Apr 2005 21:46:22 -0400
6 Date : Sat, 09 Apr 2005 19:00:47 -0700
Subject: RE: float question and mooney with lyc 0-320
7 Date : Sat, 09 Apr 2005 22:39:33 -0400
8 Date : Sat, 9 Apr 2005 18:44:25 -0800
Subject: Re: Rotax 912s exhaust system
9 Date : Sun, 10 Apr 2005 00:11:03 EDT
10 Date : Sat, 09 Apr 2005 22:43:35 -0400
11 Date : Sat, 09 Apr 2005 22:52:27 -0400
Subject: Re: Rebel tail tips
12 Date : Sun, 10 Apr 2005 08:56:16 EDT
Subject: Strontium Chromate primer - Sherwin williams
13 Date : Sun, 10 Apr 2005 10:52:54 -0400
14 Date : Sun, 10 Apr 2005 11:19:59 EDT
15 Date : Sun, 10 Apr 2005 11:30:18 -0400
16 Date : Sun, 10 Apr 2005 09:10:42 -0700
17 Date : Sun, 10 Apr 2005 18:55:49 +0000
Subject: Exhaust Support
18 Date : Sun, 10 Apr 2005 16:25:22 -0400
Subject: Elevator Trim direction/ flap position indicator
19 Date : Sun, 10 Apr 2005 14:50:54 -0600
Subject: RE: Elevator Trim direction/ flap position indicator
20 Date : Sun, 10 Apr 2005 14:54:43 -0700 (PDT)
Subject: RE: float hydro presure
21 Date : Sun, 10 Apr 2005 18:06:02 -0400
---------- Digest Message #1 ----------
Date: Sat, 9 Apr 2005 17:17:54 -0700 (PDT)
To: rebel-builders
hi,
My 0-320, 150 hp, non-dynafocal mount, engine built in 1956 came from a
money. it's model designation is 0320. there is no suffix. it is the same
as an 0-320-a1 i think. you are probably correct that since the 60's there
has not been an 0-320 mooney, but the logs that came with this freshly
overhauled 0-320 definitely say that it spent it's younger days flying
faster than it is now in my christavia mk=1.
almost all our lakes have become soft water, as opposed to ice in the last
3 days. in fact i would have done my first 2005 water landing, but, i lost
hydraulic preassure after the plane sat on a blacktop ramp for 3 hours in
70 degree temps. we finished our float install in oct so this was the
first warm high sun angle day she has sat out in.
question for the group???? do you release the preassure on you hydro in
these conditions? or do you park with nose wheels castered aft and leave
100lbs on the system??? that is what i did and one of the fittings leaked.
for those who have not done this, i took off with 0 preassure and landed
same. no problem. i do wish i'd brought the "backup" pvc locks for the
nose wheels, but i left them on my ramp so i would not forget to put them
in when i backed the plane into the hangar. i decided to put the locks in
and push it in frontwards when i got back to my hangar. i'll try to find
the problem tomorrow.
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
---------- Digest Message #2 ----------
Date: Sat, 9 Apr 2005 21:06:55 -0400
To: rebel-builders
hi andy i park with the nose gear pointing aft always then the
pressure can bleed off which it does and nothing happens
i`m going to make a set of the tubes that go over the rod on the cylinder
just for when i push backwards
what material did you use? aluminum tubing? how do you make sure it`s
out
before takoff?
bob fisher rebel 342 on 1800 amphibs parry sound ont
Sent: Saturday, April 09, 2005 8:17 PM
hi,
as
has
last
70
degree temps. we finished our float install in oct so this was the first
nose
wheels, but i left them on my ramp so i would not forget to put them in
when
i backed the plane into the hangar. i decided to put the locks in and push
it in frontwards when i got back to my hangar. i'll try to find the
problem
tomorrow.
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
---------- Digest Message #3 ----------
Date: Sat, 9 Apr 2005 21:16:41 -0400
To: rebel-builders
Wayne (and others):
The strontium chromate primer we use is covered by the following data.
It is two part epoxy and the thinner is the high humidity, blush
resistant type. One of the two companies mentioned bought the other
(don't remember which) but they should be able to cross reference.
Pratt & Lambert high solids epoxy thinner 110-059.
Pratt & Lambert epoxy primer curing agent P610421.
Sherwin Williams corrosion protective epoxy primer CM0483660.
The mix ratio is 2 resin to 1 curing agent. Mix throughly and wait 20
minutes. Then thin about 25% to spray.
Do not spray without a mask rated for this service! Read the mask
canister data and be sure.
---------- Digest Message #4 ----------
Date: Sat, 9 Apr 2005 18:30:24 -0700 (PDT)
To: rebel-builders
Hi Bob,
My partner, Clint, made the inserts out of pvc tubing, the idea came from
someone on this list. they are slit open on the bottoms to a width that
allows them to snap on over/around the cylinder rods. to assist in
installation and removal, they have pcv handles glued to them at about a
70 degree angle. to avoid departure with them installed we painted them
red. we have flown with them installed before we ready to try inflight
retraction. no problems.
hope this helps.
Andy
Do you Yahoo!?
---------- Digest Message #5 ----------
Date: Sat, 9 Apr 2005 21:46:22 -0400
To: rebel-builders
I can tell you, as I did earlier this winter that my hydraulic system does
not bleed down what so ever on my skis using the MAM pump. Howard's
amphibs
would stay at pressure all winter long in the hanger as well...so I kinda
wonder if you guys have internally leaking cylinders or check valves.
Just
a short park in the sun in -15c weather took the pressure from 100 to over
600psi shinning on my black stratoflex hoses. I'd left it a Zero after
that
and went into the hanger today +12 to find the pressure at 550psi! Sure
glad
I went with all solid (Stainless - only cause I had some preflared c/w
fittings that worked out) lines. Guess all I can say is YES, once you have
the airplane parked where you want it bleed to zero and check the gauge
often.
Sent: Saturday, April 09, 2005 9:06 PM
out
before takoff?
hi,
as
has
last
lost
70
leaked.
nose
when
push
problem
tomorrow.
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
---------- Digest Message #6 ----------
Date: Sat, 09 Apr 2005 19:00:47 -0700
To: rebel-builders
My 0320 conical mount also has no suffix. I had it overhauled as
a non certified engine, so it probably doesn't resemble anything
now. It came set up for a constant speed, but I converted it for
FP. I always thought it originally came out of a Tri-Pacer.
I always release the pressure on the selector valve and keep it
in the neutral position after the gear is cycled up or down. That
way I don't put any pressure on the lines or fittings. Just
before take-off, I do have to pump them up again, so the wheels
don't drag in the water. I use the standard MAM lines, and no
problems so far. I actually preferred the clear lines, because I
could get all the air out of the system, without any messy
bleeding.
I only use the front locks when pulling it in the hangar. With
the wheels castered back as in the moving forward position, the
gear will not collapse, but if they are castered to the front as
when pulling back, they most certainly will. I use PVC pipe for
locks, cut just enough so they pop in place around the cylinder
shaft.
As for leaks, I did have some initially on some fittings, but
managed to fix them all. In some cases, I had to change the
little brass collar to a different style from a local automotive
shop, that worked better for me.
One thing to watch for, is make sure your rubber hose from the
pump to the selector valve is not fuel line as MAM apparently
shipped to some builders. Can't remember the exact PSI, but I
think mine was 600. Bruce G. would know as he found that out the
hard way, after we flew into a remote alpine lake last summer and
it sat there in the hot sun with his selector valve not in
neutral.
Andy Bowman
Sent: Saturday, April 09, 2005 5:18 PM
hi,
1956 came from a money. it's model designation is
0320. there is no suffix. it is the same as an
the 60's there has not been an 0-320 mooney, but the
logs that came with this freshly overhauled 0-320
opposed to ice in the last 3 days. in fact i would
ramp for 3 hours in 70 degree temps. we finished our
float install in oct so this was the first warm high
preassure on you hydro in these conditions? or do you
park with nose wheels castered aft and leave 100lbs on
fittings leaked. for those who have not done this, i
took off with 0 preassure and landed same. no problem.
forget to put them in when i backed the plane into the
hangar. i decided to put the locks in and push it in
find the problem tomorrow.
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
---------- Digest Message #7 ----------
Date: Sat, 09 Apr 2005 22:39:33 -0400
To: rebel-builders
My hydraulic system loses pressure after about 10minutes I replaced the
lines with truck air brake lines and fittings I've also replaced both the
pump check valves and there's no apparent leaks so at least one of my
cylinders must have an internal leak. I can live with it the way it is now
I just have to remember to give a short stroke on the pump when on final.
Maybe a little bit of air in the system would keep the pressure from going
too high when parked.
amphibs
Just
that
glad
often.
---------- Digest Message #8 ----------
Date: Sat, 9 Apr 2005 18:44:25 -0800
To: rebel-builders
Not sure what's happening Bruce... don't understand the the "can't display
image" either... there isn't anything to display? Once you click the
upload
now button are you clicking on anything else? If so, you must not do
this... once you enter your file information and click upload now... you
need to wait until the screen shows upload successful. There is no
indication that anything is happening. Anyway, just send me the pics and
description, and I'll take care of it. Oh, and while I prefer that pics
uploaded are 640x480, it's just to make them easy to view for everybody on
the list. There are no limitations to what you upload.
Sent: Saturday, April 09, 2005 1:23 PM
Mike,
I know it has been awhile since I uploaded any pics but I have tried
several
times with the same resolute. After the upload is half complete I get a
"can't display image" message. I reduced the file size using IrfanView
but it
doesn't seem to matter.
Bruce
---------- Digest Message #9 ----------
Date: Sun, 10 Apr 2005 00:11:03 EDT
To: rebel-builders
I have found even with the selector valve in the neutral position the
pressure can built as the temperature changes. I've come to the hanger
some days
and found the lines as high as 450 psi.
As Walter said, you should make sure you were shipped hydraulic hose and
not
fuel line from MAM, or you will be cleaning hydraulic fluid from weeping
rivets and overlaps for the next year. The stuff is like Corrosion X...or
even
better.
Bruce
---------- Digest Message #10 ----------
Date: Sat, 09 Apr 2005 22:43:35 -0400
To: rebel-builders
So what this thread is saying is that it would be worth installing a
pressure relief valve if using plastic hydraulic lines...
amphibs
Just
that
glad
often.
snip
---------- Digest Message #11 ----------
Date: Sat, 09 Apr 2005 22:52:27 -0400
To: rebel-builders
Jesse Jenks wrote:
Thanks for the tips on the tips Ken.
So did the guys that installed the tip rib with flanges outboard cut a
hole
in them to clear the hinge bolts? Don't know if I'm missing something
here.
Don't know but I'd guess that they did.
Also, why did you have to make your rudder tip longer, and in what
dimension
are you talking about?
Thanks.
Jesse
It was almost a half inch too short forward and aft. I've seen one Rebel
that was the same but he just slit the trailing edge so that the
trailing edge of the tip did not wrap around the rudder. All four other
tips were a perfect fit.
---------- Digest Message #12 ----------
Date: Sun, 10 Apr 2005 08:56:16 EDT
To: rebel-builders-d
I may have used a similar epoxy primer
Sherwin Williams Aerospace Coating
meets MIL-P-23377F
two part mix
CMO724114 Adduct
and CMO724400 yellow primer
Apparently is a corrosion inhibitor and bonds pretty well to clean alum.
Wicks fairly well between riveted surfaces except for compressed contact
surfaces right under the rivet head.
Tony Wu N518R
---------- Digest Message #13 ----------
Date: Sun, 10 Apr 2005 10:52:54 -0400
To: rebel-builders
Or just leave the selector in the up position. Then any pressure change
can
vent back to the tank. Just have to remember to change the lever and give
pump before moving. And hope some helpful lineperson doesn't decide to
move
your plane while you're gone.
does
amphibs
Just
over
that
glad
have
often.
snip
---------- Digest Message #14 ----------
Date: Sun, 10 Apr 2005 11:19:59 EDT
To: rebel-builders
"Or just leave the selector in the up position."
And make sure your nose gear is castered back and/or your PVC locks are on
or you will take a nose dive! Been there and done that too.
Bruce
---------- Digest Message #15 ----------
Date: Sun, 10 Apr 2005 11:30:18 -0400
To: rebel-builders
Even when put in the up position you are going to build pressure from
sun/temp on the other side of the system back to the hydraulic pump.
Putting
in neutral, as Walter does, only protects the line from the selector to
pump. Neutral is actually a locked postion so now you have pressure
building
in both the up and down lines as neither is now vented back to tank. The
only thing I use the neutral position for is removing lines... as very
little fluid loss since no air in means no fluid out.
Ken's probably hit the nail on the head...we probably should be teeing a
pressure relief valve, set at about 300 psi, into the line from the pump
the selector valve and then be sure to leave the selector either up or
down
to protect the entire system at all times.
Sent: Sunday, April 10, 2005 10:52 AM
can
move
does
amphibs
kinda
Just
over
that
glad
have
snip
---------- Digest Message #16 ----------
Date: Sun, 10 Apr 2005 09:10:42 -0700
To: rebel-builders
I know mine does not hold pressure for any length of time, but
there are no external leaks. Has not been a problem for me, but I
just need to remember to pump up a couple of strokes prior to
take-off on water so my mains don't drag.
In fact, after reading this, I'm thinking I prefer some slight
internal leak through check valves, cylinder O rings or wherever
it is, so that I don't get any pressure build-ups in the heat. I
guess that's why I have never seen it on mine and no external
leaks. However, as I mentioned in a previous post, I do always
relieve pressure after cycling the gear and leave the selector in
neutral. I know some do it differently, but I think I'll stick
with my method, as it has served me well so far.
Sent: Sunday, April 10, 2005 7:53 AM
any pressure change can
the lever and give a
doesn't decide to move
worth installing a
pump. Howard's amphibs
cylinders or check valves. Just
left it a Zero after that
pressure at 550psi! Sure glad
some preflared c/w
and check the gauge
snip
---------- Digest Message #17 ----------
Date: Sun, 10 Apr 2005 18:55:49 +0000
To: rebel-builders
Hi Guys
I made my own exhaust system for my Christavia which was a cross over with
straight pipes. I made a small plate (about 3" x 1 1/2") and matched the
two rear center bolt holes for the oil pan. I welded two 1/2 inch (about
10"
long) tubes each pointing down towards an exhaust pipe. I then took a
piece
of 3/8 tube and made an open ended triangle that that came down from
behind
the engine to one pipe-flattened out an area to clamp to the pipe- across
the other pipe-flattened area again and then up behind the engine again. A
small piece of 3/8 pipe was welded as a support about two inches away from
each corner that attaches to the exhaust tube. When this was completed and
fitted the two exhaust stacks without any load, it was disassembled and
two upper 3/8 tubes were slid into the 1/2 tubes (telescopic) and
reassembled. When it was all snug in place and under no load, the 3/8 and
1/2 tubes were welded. I don't think it weighted a pound and was out of
way
of everything I had installed. Put about 400 hours on this system before
put the aircraft away for storage, mostly on floats and have never had a
crack-knock on wood. Will be doing something similiar when I reach the
point
with my rebel. Can also use to support throttle- mixture- carb heat
cables.
Everything is isolated to the engine. Can't get any pictures for about
another month when I take the aircraft out of storage for Oshkosh.
Steve W.
Rebel #637
---------- Digest Message #18 ----------
Date: Sun, 10 Apr 2005 16:25:22 -0400
To: rebel-builders
Todays silly question is which way are guys wiring the trim rocker
switch if installed on the instrument panel? Push the top to go nose
down or push the top to go nose up? If you think about a trim wheel or a
stick mounted trim switch then pushing the top for nose down makes
sense. Or you can just think of it as an up/down switch....
In case you think I'm totally nutty, the manufacturer supplies labelling
for either way:
http://www.rayallencompany.com/products/indsens.html
Also at the bottom of that page is a $30. position sensor that looks
like it could be used to feed one of their $77. position indicators if
someone with electric flaps wanted a panel mounted indicator.
---------- Digest Message #19 ----------
Date: Sun, 10 Apr 2005 14:50:54 -0600
To: rebel-builders
Didn't some one say once that no questions are silly?
I suspect the majority will be push the top for nose down trim, bottom for
nose up.
Scott
Sent: Sunday, April 10, 2005 2:25 PM
for either way:
---------- Digest Message #20 ----------
Date: Sun, 10 Apr 2005 14:54:43 -0700 (PDT)
To: rebel-builders
hi,
thanks to all for the helpful info. we did not finish our float install
until mid october.
as a result, we are for the first time encountering high sun angles and
70+ degree temps.
we are learning quickly what not to do. with your help we will hopfully
not have to make any more landings with zero on the presure guage.
i am inclined to go with a relief valve. my short term solution was to put
together a repair kit with the correct wrenches, hydro fluid, and some
spare fittings.
tomorrow i hope to splash for the first time in 2005.
andy
Do you Yahoo!?
---------- Digest Message #21 ----------
Date: Sun, 10 Apr 2005 18:06:02 -0400
To: rebel-builders
hi guys thanks everyone for all the interesting coments i guess this
is
why this forum is sooooo valuable bob fisher
Sent: Sunday, April 10, 2005 12:10 PM
At 10:43 PM 4/9/2005 -0400, you wrote: worth installing a hydraulic system does pump. Howard's amphibs as well...so I kinda cylinders or check valves. Just pressure from 100 to over left it a Zero after that pressure at 550psi! Sure glad some preflared c/w is YES, once you have and check the gauge ----------- https://www.dcsol.com/login?mode=HTML -----------
Welcome to the Rebel Builders List.
This mailing list is intended to provide an open
discussion forum for anyone interested in Murphy
Aircraft Ltd. Rebel series of aircraft. Whether
you're building, flying, or just trying to get
some information.
You have subscribed for the digest version of this
mailing list. This means you will receive only
one concatenated message a day, vice individual
messages.
The list archives and file libraries are located at:
The public username and password is:
username - rebel
password - builder
But you're welcome to create your own user account
so your personal configuration settings will be saved.
Subscribing and unsubscribing from lists hosted at
Maddog! BBS is handled via the following web page:
If you have any further questions or comments you can
reach the list administrator at the following address:
Power flow exhaust:
Post by Drew Dalgleish » Sat Feb 18, 2012 1:24 pm
Alvin have you looked at the powerflow for a cherokee. IIRC it hangs down
below the cowl so that may make for an easier instalation if not terribly
pretty. At least it won't be too noisy.
P.S. Please clip your posts to keep Wayne from whining about his slow
dial-up connection ;)
nose bowl cowling.
Angus McKenzie
Power flow exhaust:
Post by Angus McKenzie » Sat Feb 18, 2012 1:24 pm
Just a quick comment.
I was able to get a local shop (a friend of John Goris')to build me a new
exhaust of 2" stainless exhaust system. 1-3/4" is stock Lycoming. This shop
does sanitary piping in commercial dairies , cheese factories and the like.
All of the pipe segments are cut from mandrel bends and purge welded, TIG.
Two friends,one from Leavens and one from Leggats had involvement in the
construction of our 0-320-A2B. It has some performance extras including
+.010 0-360 pistons and big valves. Both of these mechanics felt that
performance would benefit from the larger exhaust. My friend from Leggats
lent me an 0-320 core engine/cylinders. I took in that core with my old MAM
mild steel cross-over exhaust and a new set of 4 stainless exhaust flange
blanks and ,viola, new pipes,an exact duplication including flange rings for
the heat muffs, slip joints on the cross-over,etc.
This system has no muffler and mounts only on the exhaust studs, only has
100hrs on it from last year, no cracks, good performance and a distinctive
sound. I am very pleased with it. It is a shame to have to cover the fine
welding and outstanding craftsmanship with the engine cowl as they look so
nice...............Angus
From: "Alvin and Glenys Adams" <gander.electrical@nf.sympatico.ca>
Sent: Monday, April 11, 2005 12:46 PM
Subject: Power flow exhaust:
noisy
nose bowl cowling.
Regards: Alvin
To: rebel-builders
hi,
same
there
last
lost
in
leaked.
them
in
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
To: rebel-builders
cylinder
out
before takoff?
hi,
same
as
has
last
lost
in
70
leaked.
nose
when
push
problem
tomorrow.
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
To: rebel-builders
Wayne (and others):
To: rebel-builders
Hi Bob,
from
hope this helps.
Andy
Do you Yahoo!?
To: rebel-builders
does
amphibs
kinda
Just
over
that
glad
have
often.
cylinder
it`s
out
before takoff?
same
as
has
last
lost
in
70
first
in
leave
leaked.
landed
nose
when
push
problem
tomorrow.
To: rebel-builders
bleeding.
shaft.
neutral.
Andy Bowman
hi,
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
To: rebel-builders
now
final.
going
does
amphibs
kinda
Just
over
that
glad
have
often.
To: rebel-builders
display
upload
on
Mike,
several
but it
Bruce
To: rebel-builders
some days
not
X...or
even
better.
Bruce
To: rebel-builders
does
amphibs
kinda
Just
over
that
glad
have
often.
snip
To: rebel-builders
hole
here.
dimension
Thanks.
Jesse
meets MIL-P-23377F
two part mix
CMO724114 Adduct
alum.
contact
Tony Wu N518R
To: rebel-builders
can
give
move
kinda
snip
To: rebel-builders
on
Bruce
To: rebel-builders
Putting
building
down
can
give
move
does
amphibs
kinda
valves.
Just
over
after
that
Sure
glad
c/w
have
gauge
To: rebel-builders
To: rebel-builders
Hi Guys
with
10"
piece
behind
across
A
from
way
before
point
cables.
Steve W.
Rebel #637
To: rebel-builders
for either way:
To: rebel-builders
for
nose up.
Scott
labelling
for either way:
To: rebel-builders
hi,
until mid october.
70+ degree temps.
put
spare fittings.
andy
Do you Yahoo!?
To: rebel-builders
this
is
some information.
messages.
username - rebel
password - builder
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 266.8.4 - Release Date: 3/27/2005
Power flow exhaust:
Post by Walter Klatt » Sat Feb 18, 2012 1:24 pm
Angus, did you notice an increase in performance when you went
from your old MAM mild steel exhaust to your new one?
And what did you do with your old exhaust?
I still use the old MAM mild steel exhaust on mine and have 320
hours on them so far. I did have the right ones welded in the Y
where the cross over joins, because I initially didn't have them
supported properly at the tail pipes end. However, I don't expect
them to last too much longer and either need another spare set,
or buy the new SS that most Rebels are using these days.
Angus McKenzie
Sent: Tuesday, April 12, 2005 8:57 AM
Subject: Re: Power flow exhaust:
involvement in the
extras including
mechanics felt that
friend from Leggats
noisy
speed cowl can i
have to go with tho
nose bowl cowling.
Regards: Alvin
in digest: 21
position indicator
position indicator
To: rebel-builders
hi,
suffix. it is the
same
that since the 60's
there
younger days flying
last
lost
in
oct so this was the
of the fittings
leaked.
not forget to put
them
in
andy
1088 amphibs
christavia mk=1
mich
Do you Yahoo!?
To: rebel-builders
always then the
nothing happens
the rod on the
cylinder
out
before takoff?
suffix. it is the
same
as
has
with this freshly
younger days flying
lost
in
70
of the fittings
leaked.
nose
when
push
problem
tomorrow.
To: rebel-builders
Wayne (and others):
the following data.
humidity, blush
cross reference.
CM0483660.
To: rebel-builders
Hi Bob,
from
rods. to assist in
hope this helps.
Andy
Do you Yahoo!?
To: rebel-builders
my hydraulic system
does
MAM pump. Howard's
amphibs
kinda
Just
over
that
glad
have
often.
always then the
nothing happens
the rod on the
cylinder
it`s
out
same
as
has
with this freshly
last
in
70
oct so this was the
first
in
castered aft and
leave
one of the fittings
0 preassure and
landed
nose
when
problem
To: rebel-builders
overhauled as
resemble anything
converted it for
valve and keep it
up or down. That
so the wheels
lines, and no
lines, because I
bleeding.
hangar. With
position, the
to the front as
PVC pipe for
the cylinder
shaft.
fittings, but
local automotive
hose from the
apparently
PSI, but I
found that out the
last summer and
neutral.
To: rebel-builders
also replaced both
at least one of my
now
the pump when on
final.
the pressure from
going
my hydraulic system
does
MAM pump. Howard's
kinda
over
have
To: rebel-builders
display
Once you click the
upload
so, you must not do
on
half complete I get
To: rebel-builders
some days
not
is like Corrosion
X...or
even
better.
Bruce
To: rebel-builders
worth installing a
my hydraulic system
does
MAM pump. Howard's
kinda
over
have
snip
To: rebel-builders
longer, and in what
edge so that the
meets MIL-P-23377F
two part mix
CMO724114 Adduct
alum.
for compressed
contact
Tony Wu N518R
To: rebel-builders
can
give
move
worth installing a
my hydraulic system
MAM pump. Howard's
kinda
To: rebel-builders
on
Bruce
To: rebel-builders
build pressure from
the hydraulic pump.
Putting
you have pressure
building
down
can
give
move
does
amphibs
kinda
cylinders or check
valves.
Just
over
I'd left it a Zero
after
that
pressure at 550psi!
Sure
glad
had some preflared
c/w
have
zero and check the
gauge
To: rebel-builders
of time, but
strokes prior to
some slight
rings or wherever
in the heat. I
no external
I do always
the selector in
think I'll stick
To: rebel-builders
Hi Guys
with
1 1/2") and matched
10"
pipe. I then took a
piece
that came down from
behind
clamp to the pipe-
across
A
from
(telescopic) and
way
before
point
mixture- carb heat
cables.
Steve W.
Rebel #637
To: rebel-builders
the trim rocker
the top to go nose
nose down makes
for either way:
sensor that looks
indicator.
To: rebel-builders
position indicator
for
nose up.
Scott
the top to go nose
for nose down makes
switch....
labelling
mounted indicator.
[/quote:7
Angus McKenzie
Power flow exhaust:
Hi Walter
I'm not observant enough to have noticed a difference. If it changed it was
a small amount.
The old exhaust has been repaired annually and had begun to carbonize at the
outlets. It is on a parts shelf in our shop.
The repair was usually required at the Y on the right side pipe.
We like the stainless.
Sorry we did not see you last week, Ken said he enjoyed your
visit.............Cheers, Angus
Sent: Tuesday, April 12, 2005 9:05 PM
Subject: RE: Power flow exhaust:
Angus McKenzie
involvement in the
extras including
mechanics felt that
friend from Leggats
noisy
speed cowl can i
have to go with tho
nose bowl cowling.
Regards: Alvin
in digest: 21
position indicator
position indicator
suffix. it is the
same
that since the 60's
there
younger days flying
last
lost
in
oct so this was the
of the fittings
leaked.
not forget to put
them
in
always then the
nothing happens
the rod on the
cylinder
suffix. it is the
same
with this freshly
younger days flying
lost
in
of the fittings
leaked.
push
the following data.
humidity, blush
cross reference.
CM0483660.
from
rods. to assist in
my hydraulic system
does
MAM pump. Howard's
kinda
over
have
always then the
nothing happens
the rod on the
cylinder
it`s
same
with this freshly
in
oct so this was the
first
in
castered aft and
leave
one of the fittings
0 preassure and
landed
overhauled as
resemble anything
converted it for
valve and keep it
up or down. That
so the wheels
lines, and no
lines, because I
hangar. With
position, the
to the front as
PVC pipe for
the cylinder
fittings, but
local automotive
hose from the
apparently
PSI, but I
found that out the
last summer and
also replaced both
at least one of my
now
the pump when on
final.
the pressure from
going
my hydraulic system
does
MAM pump. Howard's
kinda
over
have
display
Once you click the
so, you must not do
on
half complete I get
is like Corrosion
X...or
worth installing a
my hydraulic system
does
MAM pump. Howard's
kinda
over
have
longer, and in what
edge so that the
alum.
for compressed
contact
give
worth installing a
my hydraulic system
MAM pump. Howard's
kinda
on
build pressure from
the hydraulic pump.
you have pressure
give
cylinders or check
valves.
I'd left it a Zero
after
pressure at 550psi!
Sure
had some preflared
c/w
zero and check the
gauge
of time, but
strokes prior to
some slight
rings or wherever
in the heat. I
no external
I do always
the selector in
think I'll stick
with
1 1/2") and matched
pipe. I then took a
that came down from
clamp to the pipe-
across
A
from
(telescopic) and
before
mixture- carb heat
the trim rocker
the top to go nose
nose down makes
sensor that looks
indicator.
position indicator
for
the top to go nose
for nose down makes
switch....
labelling
moun
Power flow exhaust:
Yeah, sounds like your old exhaust cracked in the same spot as
mine.
So, this new exhaust, is this a one-of, or will it be available
for sale?
It was very interesting to see Ken's Subaru Rebel. Pretty hard to
improve on that one.
And again, if any of you guys from out east, or elsewhere ever
make it to Vancouver, look me up, and maybe we can go for a
flight.
On a side note, I was out at the Langley airport this evening,
and saw an amphib Moose with the M14P do a couple touch and go's.
Didn't catch the ident, but could have been Ryan Mowat's old
plane.
Angus McKenzie
Sent: Wednesday, April 13, 2005 7:18 AM
Hi Walter
a small amount.
side pipe.
when you went
and have 320
welded in the Y
didn't have them
don't expect
spare set,
Angus McKenzie
involvement in the
extras including
mechanics felt that
friend from Leggats
