Tip rib
Jesse Jenks
Tip rib
Post by Jesse Jenks » Sat Feb 18, 2012 1:24 pm
After much thought I decided to make my tip ribs out of 1/4" plywood or
similar. I will make them the full length of the tip, and glue in with epoxy
fillets on the inside, and glass cloth wrapped around the outside. I was
looking at the way the alum. leading edge fits into the tip (or doesn't fit
actually), and how the curve of the tip L.E. doesn't match that of the
vertical/horizontal stab, and decided to make everything fit and look good I
was going to be doing some epoxy work anyway so why not just make the whole
tip with composite materials which are more workable. This will allow me to
easily mount the counterweights on the inside of the tips as well.
The only problem I can see is changing the balance of the tips by adding a
little more weight forward of the hinge line. This will be slightly offset
by making the rib extend all the way back to the T.E.
I am very comfortable working with epoxy/wood/glass.
Any thoughts/comments?
Thanks.
Jesse
Jones, Michael
Tip rib
Post by Jones, Michael » Sat Feb 18, 2012 1:24 pm
jesse
you should not do the tips out of ply, they are balanced for a
reason,flutter maybe, you will have to rebalance them now as you are adding
allot of extra weight, be careful may cause serious design problems
mike#007
Jesse Jenks
Sent: Monday, April 11, 2005 11:53 AM
Subject: Tip rib
Thanks.
Jesse
Jesse Jenks
Tip rib
Mike,
Thanks for the comment. I think I could figure out how to end up with the
same ballance, by weighing the parts for the original setup, then cutting
off some of the led to arrive at the original amount of weight in the tip. I
suspect that the Fife tips I'm using are quite a bit lighter than the Murphy
tips as well. Also, it seems like it would be better to have a bit more
counterweight than a bit less, but I'm no expert for sure. My point is that
if getting the counterweight exactly right is a major concern, then I think
I can do that. Does anyone know what MAM says about % of counterweight in
the elevators for the Rebel? I remember some discussion about that.
Thanks again
Jesse
To: "'rebel-builders@dcsol.com'" <rebel-builders@dcsol.com>
Subject: RE: Tip rib
Date: Mon, 11 Apr 2005 12:01:15 -0400
jesse
mike#007
Jesse Jenks
Subject: Tip rib
epoxy
Thanks.
Jesse
Jones, Michael
Tip rib
don't see why you are going to this trouble, i have fife tips and they are
mounted exactly like Murphy tips, no problem at all perhaps you have missed
something in manual ??
the channel you talk about does not interfere with bolts as i recall because
it is cut short of the bolts, i think, in any case there is no need to go to
all this extra work, sit down and have another look at the problem, you
should see they go together as Murphy says, don't mess with the counter
weights
mike#007
Jesse Jenks
Sent: Monday, April 11, 2005 12:18 PM
Mike,
Thanks again
Jesse
jesse
mike#007
Jesse Jenks
Subject: Tip rib
epoxy
Thanks.
Jesse
Tip rib
Post by Ken » Sat Feb 18, 2012 1:24 pm
Jesse
I agree with Mike that this is extra work for minimal gain however we
are all guilty of that ;)
Yes you can't really have too much counter weight. You don't want too
little. If anything you want extra counterweight to allow for any extra
material that you add behind the elevator hinge point. So ideally you'd
measure the stock moment arm of the tip and make sure you have a similar
amount of moment arm. In reality I doubt if it is very critical but that
will keep you on the safe side as far as I know.
Also make sure you don't create any traps (figuratively and literally)
such as could the plywood absorb moisture and freeze or trap water or
ice back there at the aft part of the tip - that could cause problems
(upset the balance and lead to flutter) and that sort of thing has
killed pilots.
Jesse Jenks wrote:
Mike,
tip. I
Murphy
that
think
Thanks again
Jesse
Jesse Jenks
Tip rib
Thanks Ken,
I would seal the ply in epoxy, and make sure there is a way for moisture to
drain from the enclosure. I read Bingelis on mass balancing last night. He
sais 100% or more is best. The standard MAM setup seems less than 100%. Also
as I remember the trim system is optional, but the manual doesn't say (I
think) to adjust the counterweight for what must be quite a big difference
in weight aft of the hinge line. Has anyone actually ballanced to 100%? I
wonder how much lead it would take. Another interesting point from Bingelis
was a quote from some FAA bulletin saying the actual balance weight should
be mounted to take something like 24G. In case it does flutter I guess. I
think the fiberglass tip would rip off at 24G in flutter mode (whipping up
and down). That's another reason to beef it up. What got me started on the
whole thing though was that the nose profile of the tip doesn't match the
profile of the stabs. It doesn't look great, but more importantly the L.E.
rib doesn't fit properly in the tip. At first I was thinking I would use
thickened epoxy between the rib and the inside of the tip to fill the voids
caused by the mismatch, let it harden then rivet. This is still not a bad
idea I think, because if you just rivet it as is then something has to give.
Probably the fiberglass. Then I thought I wanted to re contour the profile
on the outside of the tip L.E. to better match the stab. With those 2
operations, it didn't make much sense to be using aluminum and rivets. I
think it would actually be less work to just make the rib out of ply and
epoxy/glass it in.
Jesse
Subject: Re: Tip rib
Date: Tue, 12 Apr 2005 09:11:35 -0400
Jesse
killed pilots.
Jesse Jenks wrote:
Mike,
cutting
tip. I
Murphy
that
think
in
Thanks again
Jesse
Tip rib
Jesse
I didn't have to adjust mine but I do remember Dave saying that the tip
could be narrowed to change the leading edge curve angle (contour?). ie
if you are looking down vertically at the tip, you can cut some off the
open edge (reduce the span of the stab). That results in a shorter tip
in the forward to aft direction as the tip effectively slides onto the
elevator farther.
It doesn't sound like that is your contour issue though??. Things can be
a fair way from perfect and still be virtually unnoticeable by someone
else with a less critical eye, but by all means do what you think is
best and easiest for you. Regardless of what you do they are going to
look better than the stock tips I think.
100% mass balancing is great for an untested product but not really
necessary if the structure is flight tested OK and kept below Vne. I
think you can be certain that there is sufficient counterweight there
for the stock construction and normal speeds. That's the advantage of a
tested and well proven design. You are doing the right thing by doing
your homework before making changes. Also I think the Fife tip is
already stronger than the stock tip as far as I can tell so no worries
there.
Jesse Jenks wrote:
Thanks Ken,
epoxy/glass it in.
Jesse
Jesse Jenks
Tip rib
I started fitting the rudder tip last night. after I cut 1 1/8" off the
forward half of the tip, and slit the T.E. to get the tip and Rudder T.E.
flush, the nose of the tip is about 1/4" shy of the nose contour of the
vert. stab. So yes, my contour problem, is in the other direction ie I need
to make it bigger. I like the look of the T.E. with the tip slit though. It
is a straight line, instead of having a joggle where the tip starts.
Another question regarding the tips: I remember something about post curing
of the tips on Dave's website, but I can't find the site anymore. Does
anyone have the URL, or info on post cure? I would like to do it before
getting too far along on the tips.
Thanks.
Jesse
Jesse
elevator farther.
there.
Jesse Jenks wrote:
Thanks Ken,
He
Also
difference
Bingelis
should
up
L.E.
voids
give.
profile
epoxy/glass it in.
Jesse
