Jesse bought a whole airplane kit from me and why I said I'd send him some
N/C......
As previously posted......anyone that wants them just send me $5 >CASH< and
your address and I will send you a dozen. US folks US dollars and Canadian
folks CDN dollars, as this will cover the higher postage rate to the USA.
These are only for the Rebel though TTBOMKnowledge, so Keith I'm not sure if
you need them. The washers themselves are about 2" OD with a 3/8 ID hole
that fits the hinge bushing perfectly. They are about 0.032/0.040 thick and
made of nylon 6. You will never wear them out....OEM usage was the thrust
washer for TRW seatbelts, to keep the recoil spring from wearing thru the
Polypro case.
On the Rebel they are used between the hinge brackets and the
elevator/rudder spar tubes end plugs and the rivets holding the push pull
horns on. The rudder is absolutely critical as without the washer in place
the rivets will chew their way through the lower hinge bracket thanks to
gravity.
Wayne O'Shea
1516 Alvin Williams Rd
Penetanguishene, Ontario
L9M-2C1
kb_oliver@verizon.net>
To: <
rebel-builders@dcsol.com>
Sent: Monday, April 11, 2005 4:22 PM
Subject: RE: nylon washers
I could use some also
Would be more than happy to pay for them
Keith B. Oliver
ELITE N654ME (reserved)
Farmingdale, Maine
mike.davis@dcsol.com [mailto:
mike.davis@dcsol.com]On Behalf Of
Sent: Monday, April 11, 2005 12:41 PM
To:
Subject: Re: nylon washers
Jesse, did I not throw a dozen in of my thrust washers?? MAM used to have
nothing there, then bought about 2000 from me and then switched to
something
inferior in my mind. Give me your mailing address again and I send you
some.
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
