Elevator Trim direction/ flap position indicator
Posted: Sat Feb 18, 2012 1:24 pm
Todays silly question is which way are guys wiring the trim rocker
switch if installed on the instrument panel? Push the top to go nose
down or push the top to go nose up? If you think about a trim wheel or a
stick mounted trim switch then pushing the top for nose down makes
sense. Or you can just think of it as an up/down switch....
In case you think I'm totally nutty, the manufacturer supplies labelling
for either way:
http://www.rayallencompany.com/products/indsens.html
Also at the bottom of that page is a $30. position sensor that looks
like it could be used to feed one of their $77. position indicators if
someone with electric flaps wanted a panel mounted indicator.
for either way:
