epoxy primer/zinc chromate
bscheube
Hi all,
This is a question that has been asked alot (as my search of the archives has
shown me also seems to have confused me) So I am asking again to see if I can
get a clear picture.
What is the criteria for using the epoxy primer as opposed to the zinc
chromate to prime the mating surfaces, rivets, nutplates etc. is there one. Is
one better than the other. any suggestions would be helpful.
thanks. Bob Scheuber
Bob, both will kill you over time without proper ventilation...but the zinc
types (like you will find in old Cessna's the where seaplane mods) tend to
turn to flakes/powder over time and then you get to breath it in! Stay away
from Zinc...try to find some Epoxy Chromate primer as was the old
Stits/polyfiber EP420/430...but it has been reformulated in the last few
years and the chromate appears to have been removed as well...leaving it as
just Epoxy primer. Anything that you can get between the seams WET and get
riveted down while it is still wet..will greatly reduce any chances of
corrosion in the seams and also helps considerably with shear strength of
panel overlaps.
Sent: Thursday, April 07, 2005 5:50 PM
Subject: epoxy primer/zinc chromate
panel overlaps.
hasHi all,
canshown me also seems to have confused me) So I am asking again to see if I
one. Isget a clear picture.
bscheube
Thanks for the info Wayne
Bob Scheuber
SR191
On 4/7/2005 2:01 PM, OIFA@IRISHFIELD.ON.CA wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Thu, 07 Apr 2005 14:00:22 -0800
-> Received: from smtp.film-tech.net ([66.98.221.156]) EHLO=smtp.film-tech.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 203942250; Thu, 07 Apr 2005 14:00:20 -0800
-> Received: from dilbert.dostech.net (barrie-dialport-
216.209.18.167.csolve.net [216.209.18.167])
-> (authenticated user dos@smtp.film-tech.net)
-> by smtp.film-tech.net (smtp.film-tech.net [66.98.221.156])
-> (Cipher TLSv1:RC4-MD5:128) (MDaemon.PRO.v6.8.5.R)
-> with ESMTP id 19-md50000000224.tmp
-> for <rebel-builders@dcsol.com>; Thu, 07 Apr 2005 17:00:14 -0500
-> Received: from celeron266a (celeron266a.midland.dostech.net [10.145.1.228])
-> by dilbert.dostech.net (8.12.8/8.12.
with SMTP id j37LxQ4P031595
-> for <rebel-builders@dcsol.com>; Thu, 7 Apr 2005 17:59:27 -0400
-> Message-ID: <002d01c53bbd$4c59d2e0$e401910a@celeron266a>
-> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> References: <1112910658@dcsol.com>
-> Subject: Re: epoxy primer/zinc chromate
-> Date: Thu, 7 Apr 2005 18:01:05 -0400
-> Organization: O'Shea's Irish Field Aviation
-> X-Orig-MIME-Version: 1.0
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1106
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
-> X-Authenticated-Sender: dos@smtp.film-tech.net
-> X-Spam-Processed: smtp.film-tech.net, Thu, 07 Apr 2005 17:00:14 -0500
-> (not processed: spam filter disabled)
-> X-MDRemoteIP: 216.209.18.167
-> X-Return-Path: oifa@irishfield.on.ca
-> X-MDaemon-Deliver-To: rebel-builders@dcsol.com
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Bob, both will kill you over time without proper ventilation...but the zinc
-> types (like you will find in old Cessna's the where seaplane mods) tend to
-> turn to flakes/powder over time and then you get to breath it in! Stay away
-> from Zinc...try to find some Epoxy Chromate primer as was the old
-> Stits/polyfiber EP420/430...but it has been reformulated in the last few
-> years and the chromate appears to have been removed as well...leaving it as
-> just Epoxy primer. Anything that you can get between the seams WET and get
-> riveted down while it is still wet..will greatly reduce any chances of
-> corrosion in the seams and also helps considerably with shear strength of
-> panel overlaps.
-> Wayne
-> From: <bscheube@dcsol.com>
-> Sent: Thursday, April 07, 2005 5:50 PM
-> Subject: epoxy primer/zinc chromate
-> > Hi all,
-> > This is a question that has been asked alot (as my search of the archives
-> has
-> > shown me also seems to have confused me) So I am asking again to see if I
-> can
-> > get a clear picture.
-> > What is the criteria for using the epoxy primer as opposed to the zinc
-> > chromate to prime the mating surfaces, rivets, nutplates etc. is there
-> one. Is
-> > one better than the other. any suggestions would be helpful.
-> > thanks. Bob Scheuber
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
Bob Scheuber
SR191
-> X-Priority: 3
-> panel overlaps.
-> Wayne
-> > Hi all,
-> has
-> can
-> one. Is
Jean Poirier
Hello Bob
Wayne is true when he talk about zinc chromate... but I have work with the
polyfiber primer and I didn't like it. When apply with a acid brush after
good clean up and scothbrite, the primer still want to sometimes "roll"
.... like it do not want to "glue on aluminium" and the price is in the
range of aircraft parts.... Go to a good automobile body products supplier
and ask for a "self etching epoxy primer", better adherance, cheaper and
easy to find
Jean
Rebel 747R
easy to find
Jean
Rebel 747R
Hi all,
has
can
one. Is
You could be correct Jean...I haven't had to use any of the non-chromate
EP420 yet....on my last can of the good stuff.!
Sent: Thursday, April 07, 2005 8:06 PM
theHello Bob
supplierpolyfiber primer and I didn't like it. When apply with a acid brush after
archivesand ask for a "self etching epoxy primer", better adherance, cheaper and
easy to find
Jean
Rebel 747R
Hi all,
Ihas
can
one. Is
We have used Sherwin Williams 2 part epoxy strontium chromate epoxy on
our Elite. I'm told it is what Boeing uses at their facility here in
South Carolina. There is a solvent that resists high humidity blush
available (which we used). I can put the product numbers on the list if
anyone is interested.
Rallph Baker
Rallph Baker
Of course we are Ralph....list the Product #'s.
Sent: Thursday, April 07, 2005 9:07 PM
Rallph Baker
bscheube
Thanks Jean,
may have found a good deal on e-bay for some. I am going to give it a try.
Bob SR191
On 4/7/2005 4:16 PM, OIFA@IRISHFIELD.ON.CA wrote to REBEL-BUILDERS:
-> for rebel-builders@dcsol.com; Thu, 07 Apr 2005 16:16:03 -0800
-> id 212082609; Thu, 07 Apr 2005 16:16:01 -0800
-> with ESMTP id 17-md50000000225.tmp
-> for <rebel-builders@dcsol.com>; Thu, 07 Apr 2005 19:15:30 -0500
with SMTP id j380Ef4P031985
-> for <rebel-builders@dcsol.com>; Thu, 7 Apr 2005 20:14:41 -0400
-> Message-ID: <00c801c53bd0$319e6e30$e401910a@celeron266a>
-> References: <1112910658@dcsol.com> <002601c53bce$e2a2f7c0$0500000a@JEAN>
-> Date: Thu, 7 Apr 2005 20:16:21 -0400
-> X-Priority: 3
-> X-Spam-Processed: smtp.film-tech.net, Thu, 07 Apr 2005 19:15:30 -0500
-> You could be correct Jean...I haven't had to use any of the non-chromate
-> EP420 yet....on my last can of the good stuff.!
-> From: "Jean Poirier" <oxyport@globetrotter.net>
-> Sent: Thursday, April 07, 2005 8:06 PM
-> > Hello Bob
-> > Wayne is true when he talk about zinc chromate... but I have work with
-> the
-> > polyfiber primer and I didn't like it. When apply with a acid brush after
-> > good clean up and scothbrite, the primer still want to sometimes "roll"
-> > .... like it do not want to "glue on aluminium" and the price is in the
-> > range of aircraft parts.... Go to a good automobile body products
-> supplier
-> > and ask for a "self etching epoxy primer", better adherance, cheaper and
-> > easy to find
-> > Jean
-> > Rebel 747R
-> > ----- Original Message -----
-> > From: <bscheube@dcsol.com>
-> > To: <rebel-builders@dcsol.com>
-> > Sent: Thursday, April 07, 2005 5:50 PM
-> > Subject: epoxy primer/zinc chromate
-> > > Hi all,
-> > > This is a question that has been asked alot (as my search of the
-> archives
-> > > has
-> > > shown me also seems to have confused me) So I am asking again to see if
-> I
-> > > can
-> > > get a clear picture.
-> > > What is the criteria for using the epoxy primer as opposed to the zinc
-> > > chromate to prime the mating surfaces, rivets, nutplates etc. is there
-> > > one. Is
-> > > one better than the other. any suggestions would be helpful.
-> > > thanks. Bob Scheuber
-> > > List archives located at: https://www.dcsol.com/login?mode=HTML
-> > > username "rebel" password "builder"
-> > > Subscription services located at:
-> > > https://www.dcsol.com/public/code/html-subscribe.htm
-> > > List administrator: mike.davis@dcsol.com
Bob SR191
-> X-Priority: 3
-> > Hello Bob
-> the
-> supplier
-> > easy to find
-> > Jean
-> > Rebel 747R
-> > > Hi all,
-> archives
-> > > has
-> I
-> > > can
-> > > one. Is
I couldn't tell the difference when they stopped using chromate other
than the streaks in the can when you first start stirring it changed
from black to white...
