Cracks in tail stinger bulkhead
Posted: Sat Feb 18, 2012 1:20 pm
Hi Gang,
Brian Godden has been here for the past three days helping do the annual
inspection of the Moose,
464 hours total time, 74 hours on wheels, 390 on floats, 200 hours this past
year. I had noted that the tail wrap fitting where the stinger exits the
tail cone had damage.
Brian found cracks in the bulkhead that holds the tail stinger, it was the
first place he looked. Brian's comment was "that is where they all crack".
He said Darryl's position was that the cracking was an anomaly.
Brian's fix was to install an angle on each side over the crack and attach
the angle to the side of the tailcone by added an additional angle down the
side of the tail wrap, backing the existing flange.
We are not sure the fix is a great fix, needs more engineering. Brian thinks
the bulkhead is way under designed for the size of the airplane and that
area need lots of beefing up. My friend Graham Clapp, retired Boeing
Structures Engineer says the stinger needs to float in a shock mount at the
forward end. That will absorb some of the shock load of the stinger. He
thinks the rigid mounting is a major part of the problem.
I just don't know what to think, what do you guys think? I will post
pictures.
Al
Moose, N526AP
pictures.
Al
Moose, N526AP
