Cessna pitot tube
Posted: Sat Feb 18, 2012 1:20 pm
by Ken
Is anyone satisfactorily using a Cessna heated pitot tube? If so where
did you locate it?
From the archives, I know that Bob doesn't recommend the Cessna probe.
The one that I have here has a 1/8" dia inlet although it could be
enlarged. To my surprise it also has a 1/16" water drain at the bottom
rear which I expect would release some of the ram pressure and make the
ASI tend to read low. Has anyone tried plugging the drain? Or tilting
the probe down?
The bracket that I have would place the probe 2.5" below the wing
although I'd prefer about twice that.
List archives located at:
https://mail.dcsol.com/login
Unsubscribe:
List administrator:
mike.davis@dcsol.com
Cessna Pitot tube
by Garry Wright
There are pitot tubes listed periodically on ebay - you just have to
watch for them.
I have just aluminum tube projecting about a foot forward of the wing
and wonder if anyone has a method to electrically heat such a unit?
Garry Wright
068R Amphib C-FOKM
403 931 1573
wrightdg@ca.inter.net
Unsubscribe:
List administrator:
Cessna pitot tube
by Lonnie Benson
Ken, have you checked out
www.gretzaero.com/ for a longer mounting
bracket?
klehman@albedo.net>
To: <
rebel-builders@dcsol.com>
Sent: Tuesday, March 29, 2005 9:55 PM
Subject: Cessna pitot tube
Unsubscribe:
List administrator:
Cessna pitot tube
by Ken
Yes thanks Lonnie.
I was thinking of trying to squeeze a length of 1.5" aluminum tubing
into the appropriate shape or trying it as is first.
bracket?
klehman@albedo.net>
To: <
snip>
Unsubscribe:
List administrator:
Cessna pitot tube
I bought a one foot length of streamline 4130 tubing from ACS and mounted it
up inside to the side of a l-edge rib. Fits the tube prefectly. I have some
long lengths of streamline from my Norseman parts collection. Will see if
it's the right size for a heated p tube..but I think one size is too small
and other is too big.
klehman@albedo.net>
To: <
Sent: Wednesday, March 30, 2005 2:11 PM
Subject: Re: Cessna pitot tube
Yes thanks Lonnie.
bracket?
klehman@albedo.net>
To: <
snip>
https://www.dcsol.com/login?mode=HTML
List administrator:
Unsubscribe:
List administrator:
Cessna pitot tube
by Alan Hepburn
I bought the heated pitot, mast, mounting plate as a unit from a wrecker and
installed it as close to the original (Cessna) setup as possible - just
outboard of the strut attach point. I just used a doubler on the wing skin,
right next to a rib. It's on an Elite, so the skins are 0.025".
Performance is still TBD, as the aircraft has not yet flown (but getting
close).
Al Hepburn
klehman@albedo.net>
To: <
did you locate it?
the probe down?
List administrator:
Unsubscribe:
List administrator:
Cessna pitot tube
by David Ricker
You can pick up a piece of faired tubing in steel that is a good fit at
AC Spruce or in aluminum at Wicks. I made the mount for our Elite from
the steel.
Ken wrote:
Yes thanks Lonnie.
bracket?
klehman@albedo.net>
To: <
snip>
List administrator:
David A. Ricker
Fall River, Nova Scotia
Canada
Unsubscribe:
List administrator:
Cessna pitot tube
by Warren & Marg Montgomery
I used the RV extension kit as sold by AS&S. Also mounted through one of
the fwd inspection covers in the strut area.
The streamlined tubing has a flange welded to it and is chromed. Looks
nice but Wayne could weld the same up for a lot less I'm sure..
My PT is 28v and still not sure if I want 12v or 28v. I had gone with 28
as the Garmin 430 initally only came at 28v but it's now also 12v.
klehman@albedo.net>
To: <
List administrator:
Unsubscribe:
List administrator:
Cessna Pitot tube
by Ken
Hi Garry
Take a look at:
http://www.periheliondesign.com/downloads.htm
watch for them.
Unsubscribe:
List administrator:
