Air riveter
Air riveter
I finally got an air riveter, and used it to rivet a horizontal stab the
other day. I have a few questions about its operation.
1) How do you get a slower pull? I have a hard time modulating the pull
speed. I tried turning down the line pressure to the minimum required to
still pull the rivet, and still can't really slow it down.
2) The mandrels don't eject out the back of the puller head most of the
time. I have to either turn the riveter upside-down and shake it until the
mandrel falls out, or if it sticks in the jaws, then I have to pull it out
the front by hand. This is a real pain. Shouldn't they just eject out the
back? There is a plastic shroud there to catch them.
I got it at Harbor Freight. It's the Central Pneumatic one.
Jesse
Jesse
Air riveter
Jesse..not much you can do about the speed other than putting a flow control
in your air line. I use about 60 psi to pull the RV1410s and 100 to pull the
RV1613/19's. I can feather my trigger somewhat for a bit slower pull, but
not much. Never been an issue.
Pull the nose cover off the riveter. One of the wrenches that came with the
unit should have a gauge that is used to set the nose distance. Don't worry
if you don't have it..never works right anyhow. If mandrels aren't falling
out and the nose piece itself isn't too tight...Loosen the jam nut on the
nose piece and move the jaw assembly forward 1/2 a turn. Tighten the jam
nut, put the nose cover back on and give it a try.
Sent: Thursday, March 03, 2005 9:23 PM
Subject: Air riveter
Jesse
Air riveter
Thanks Wayne,
I'll give the jaw adjustment a try. I think I have a flow control valve. I
can adjust the line pressure. Is that the same? I was using about the same
psi you said for the different rivet sizes. It seems to work fine with a
fast pull, I was thinking ahead to the Proseal though. I can use my
Rive-drill for that though. It will go as slow as you want.
Jesse
Jesse
Subject: Re: Air riveter
Date: Thu, 3 Mar 2005 21:39:49 -0500
control
theI finally got an air riveter, and used it to rivet a horizontal stab the
time. I have to either turn the riveter upside-down and shake it untiloutmandrel falls out, or if it sticks in the jaws, then I have to pull itthethe front by hand. This is a real pain. Shouldn't they just eject outback? There is a plastic shroud there to catch them.
Jesse
Air riveter
Pressure is one thing, flow is another. Pressure is psi in the line, flow is
restricted with a needle valve or similar. If you have a gate valve on your
compressor tanks line feed you may be able to just crack it when you want a
slower pull. Others have just used 20 or 30 psi to "half" pull the rivets
when doing proseal and then turned up to the normal 60 or so to finish the
pull and break the mandrels. I've never bothered buying into this half pull
/ full pull theory myself.
Sent: Thursday, March 03, 2005 10:13 PM
sameThanks Wayne,
thepsi you said for the different rivet sizes. It seems to work fine with a
Jesse
control
worryunit should have a gauge that is used to set the nose distance. Don't
fallingif you don't have it..never works right anyhow. If mandrels aren't
theout and the nose piece itself isn't too tight...Loosen the jam nut on the
pullother day. I have a few questions about its operation.
tospeed. I tried turning down the line pressure to the minimum required
thestill pull the rivet, and still can't really slow it down.
thetime. I have to either turn the riveter upside-down and shake it untiloutmandrel falls out, or if it sticks in the jaws, then I have to pull itthethe front by hand. This is a real pain. Shouldn't they just eject outback? There is a plastic shroud there to catch them.
Jesse
Air riveter
Wayne,
OK, as per usual I remain thick-headed but I can't figure the point of slow
or half pulling proseal rivets vs, avex? If enough black goo is inside and
out I can't think a rivet would shove proseal out of the way any more than
chromate.
John...
At 09:42 PM 03/03/05, you wrote:
and reflect."
Mark Twain
chromate.
John...
"Whenever you find yourself on the side of the majority, it's time to pausePressure is one thing, flow is another. Pressure is psi in the line, flow is
sameThanks Wayne,
can adjust the line pressure. Is that the same? I was using about thethepsi you said for the different rivet sizes. It seems to work fine with a
Jesse
control
Pull the nose cover off the riveter. One of the wrenches that came withworryunit should have a gauge that is used to set the nose distance. Don'tfallingif you don't have it..never works right anyhow. If mandrels aren'ttheout and the nose piece itself isn't too tight...Loosen the jam nut on the
pulltothethe out the
and reflect."
Mark Twain
Air riveter
Hello John
I have much less experience than Wayne but if you want to be sure that in
the proseal area the 2 parts have the "time" to squeeze out the the over of
proseal, just use a hand riveter and go slowly. There is not a big
quantity of rivets involve, and you don't fill you air riveter with a very
but very stiky "air tool grease"
Jean
Rebel 747R
Sent: Friday, March 04, 2005 12:55 PM
Jean
Rebel 747R
Wayne,
slow
chromate.
John...
At 09:42 PM 03/03/05, you wrote:"Whenever you find yourself on the side of the majority, it's time toPressure is one thing, flow is another. Pressure is psi in the line, flow
is
your
pull
sameThanks Wayne,
valve. I
Jesse
worryfallingthepulltothe
pause
and reflect."
Mark Twain
Air riveter
You guys all missed my view on that (even #1 son...can tell he's run away
every time the puppy $hit comes out LOL)!
I >>DO NOT<< slow pull or 1/2 pull rivets when doing a fuel tank while
playing with proseal and why I stated "I've never bothered buying into this
half pull / full pull theory myself". I do set the gun a little lower in
pressure when pulling the tank Rivets RR640x as they will split open if
pulled too hard. 45 to 50 psi does the trick and the cleco's you have
holding the assembly together will have oozed the proseal as far as it needs
to be compressed. Pull the darn rivets and then take a Popsicle stick and go
around and fillet the small bit more the proseal oozes out.
Sent: Friday, March 04, 2005 2:20 PM
tooThanks Jean & Daryl,
More points to ponder and techniques to remember. The learning curve on
these things is pretty steep for a mental junk pile that is already way
offull and slowing down by the day.
John...
At 12:41 PM 03/04/05, you wrote:Hello John
veryproseal, just use a hand riveter and go slowly. There is not a big
insidebut very stiky "air tool grease"
Jean
Rebel 747R
Wayne,
slow
thanand
flowchromate.
John...
want
rivets
with
flow
pull,
Don't
on
most
it
pull
eject
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~"Whenever you find yourself on the side of the majority, it's time to
pause
and reflect."
Mark Twain
Fly too low or too slow and the ground will rise up and smite thee.
Air riveter
I didn't miss the point of view, I just pointed out the reasoning behind
the other one!
That crap is too gooey to 'shove' out of there.
the other one!
Air riveter
John Kramer wrote:
fuel leak down the road.
Daryl
You don't have to worry about chromate being shoved away and causing aOK, as per usual I remain thick-headed but I can't figure the point of slow
chromate.
Daryl
Air riveter
these things is pretty steep for a mental junk pile that is already way too
John...
John...
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~Hello John
Jean
Rebel 747R
Wayne,
slow
chromate.
John...
is
your
pull
same the worry falling the pull to the
pause
and reflect."
Mark Twain
Air riveter
Message received!!! Daddy..... ha ha ha
Jean
Rebel 747R
Sent: Friday, March 04, 2005 4:48 PM
Jean
Rebel 747R
this
needs
go
these things is pretty steep for a mental junk pile that is already wayoffull and slowing down by the day.
John...
in
the proseal area the 2 parts have the "time" to squeeze out the the oververyproseal, just use a hand riveter and go slowly. There is not a big
quantity of rivets involve, and you don't fill you air riveter with ainsidebut very stiky "air tool grease"
Jean
Rebel 747R
thanflowwantrivetsthethewithflowtopull,Don'tonthethemostitpulleject~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
