912 performance
Aurele Lavigne
912 performance
Post by Aurele Lavigne » Sat Feb 18, 2012 10:10 am
Ian, I changed the thread line as tyhe discussion has gone away from "fuel
sight gauges.
While I'm running the 912 and not 912S, it sounds like you're missing out on
at least 20% of you're power range at 5400. While you will notice some
difference in fuel consumption, climbing at 5800 and cruising at 5400, you
will like the added performance/speed when you need or want it. Of course
when you just want to soar and explore, you can always throttle back.
I use a 3-blade Ivoprop, in-flight adjustable, but it is not recommneded for
the 100hp. Too bad because you get great performance range and fuel economy
and all that for about $1000 US.
I regularly push my rpm to 6000 on take off to get off the water in short
distances and ease back within a minute or two max, then 5800 to altitude
for up to 5 minutes and cruise at 5400.
I read an article a few years ago by a company who operated a fleet of 912's
and one common problem they reported was that their pilots babied these
engines too much.
Like Bob said, we get 90kts cruise with the 80hp.
Hope this helps,
Aurele
R063
P.S. I assume you have the airbox with your 100hp, and if so would
appreciate any pics on that set-up, with corresponding cold and hot air
intake setup. Just send to me offllist if you can.
Sent: Tuesday, February 15, 2005 6:20 AM
Subject: Re: Rebel- fuel sight gauges
G'day
So, if I fly to the north of Australia nearer the equator the Rebel won't
spin at all?
Actually, it means you spin to the left instead of the right!
Regards
Ian>
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.8 - Release Date: 14/02/2005
No virus found in this outgoing message.
912 performance
Post by Walter Klatt » Sat Feb 18, 2012 10:10 am
Aurele, what floats are you using? What type of performance are
you getting with the 912 on floats? Do you have any timings for
take-off at a given gross weight?
Aurele Lavigne
Sent: Tuesday, February 15, 2005 8:48 AM
Subject: Re: 912 performance
sight gauges.
will notice some
want it. Of course
throttle back.
the water in short
pilots babied these
engines too much.
Hope this helps,
Aurele
R063
if so would
cold and hot air
G'day
spin at all?
the right!
Regards
Ian>
Date: 14/02/2005
Date: 14/02/2005
IAN DONALDSON
912 performance
Post by IAN DONALDSON » Sat Feb 18, 2012 10:12 am
on
Well that is something that I will experiment with. I notice that the speed
does increase markedly as the revs come up.
912's
engines too much.
There is a Rotax 80hp here in a training plane that has in excess of 3000
hours abd it gets a hard time. The last time it went in for overhaul it
measured up as standard> that says something about the quality of the Rotax.
No I don't have an airbox or carby heat, as the standard setup from the
factory does not allow for them, so I have never bothered to modify things
to fit one on. I was concerned about carby ice, but I have flown in icing
conditions and have not had a problem. I would be pleased to know if anyone
else has carby heat!
Regards
Ian Donaldson
Aurele Lavigne
912 performance
Post by Aurele Lavigne » Sat Feb 18, 2012 10:12 am
Walter, not sure of make of my floats, they were purchased by the original
owner and I beleive made in Quebec, Canada somewhere. They straight aluminum
and I figure, 1300's give or take.
As for performance, it's not bad considering you're talking an 80 hp. Never
took any times off the water, but alone with half a tank +/- 10 US gallons,
pilot 150lbs, empty weight 625lbs, 40 lbs of gear in the back, I scared
myself silly one day gazing at shore as I powered up and was off the water
in well under 10 seconds.
On an extreme hot day, 30C+ took a 180lb passenger and it was an extremely
long take off, but we were up flying. It was hard getting any lift and climb
was virtually nil. Having said this, a C172 tried 4 times without luck and
never got up.
Also had a 220lb passenger one day and no problem getting her in the air. I
would estimate gross with a passenger, 1/2 fuel, on floats at just under
1200lbs and under typical summer conditions, in light wind, I'd be off
within 15 seconds. I will however take some numbers this summer if you're
interested.
Note that I am using an in-flight adjustable prop from Ivoprop and this has
enhanced pewrformance somewhat on take off and cruise. Cruise in neutral
conditions isn't fast, probably about 70kt range.
If you like I can send you pics of the floats directly.
Aurele
R063
Sent: Tuesday, February 15, 2005 3:10 PM
Subject: RE: 912 performance
you getting with the 912 on flats? Do you have any timings for
Aurele Lavigne
sight gauges.
will notice some
want it. Of course
throttle back.
the water in short
pilots babied these
engines too much.
Hope this helps,
Aurele
R063
if so would
cold and hot air
G'day
spin at all?
the right!
Regards
Ian>
Date: 14/02/2005
Date: 14/02/2005
912 performance
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:12 am
He departed a Provincial Park in a hell of a hurry after the Warden had a
little talk with us ! LOL :O)))
Sent: Wednesday, February 16, 2005 11:53 AM
aluminum
Never
gallons,
climb
never got up.
interested.
has
Aurele
R063
Aurele Lavigne
sight gauges.
will notice some
want it. Of course
throttle back.
the water in short
pilots babied these
engines too much.
Hope this helps,
Aurele
R063
if so would
cold and hot air
equator the Rebel won't the right! -------------------------------------------------------
---------- https://www.dcsol.com/login?mode=HTML -------------------------------------------------------
---------- Date: 14/02/2005
Date: 14/02/2005
Aurele Lavigne
912 performance
Ian, the airbox has been added as a standard installation for all 912's. See
the Rotax sight and see the SB or I can send you a link.The air box won't
make that much difference, but every inch of improvement is worth in my
opinion. It will equalize the air intake as opposed to the turbalent air
from inside the cowl.
Most 912's don't need carb heat from my experience, but will not it with an
air box.
I made my air box with my local AME for 1/4 of the price of Rotech's.
Besides the Rotech one won't fit the Rebel's installation since our intakes
have been reversed to allow a fit within our engine mount, so need to custom
build the airbox.
Had a blueprint of the airbox at one time, so if you're ever thinking of
making one will dig it out.
Aurele
R063
Sent: Wednesday, February 16, 2005 7:49 AM
on
you
speed
912's
engines too much.
Rotax.
anyone
Regards
Ian Donaldson
Aurele Lavigne
912 performance
Wayne, no need to bring that up. LOL And by the way, that wasn't one of by
best take offs. I was under a lot of pressure.
Glad to see you're feeling better after you're freak accident.
While you're here, I'm looking for a set of vaccum gauges for pneumatic
synchronization of carbs on the 912. Do you have such a beast???
Thanks, Aurele
R063
Sent: Wednesday, February 16, 2005 11:55 AM
original
aluminum
Never
gallons,
water
extremely
climb
never got up.
interested.
has
Aurele
R063
912 performance
Available from Lockwood Aviation Supplies in Florida for $79.75US
www.lockwood-aviation.com lockwood@digital.net
Probably others as well, but I always see their advert in EAA's Experimenter
(now Sportpilot)
Sent: Wednesday, February 16, 2005 12:36 PM
Thanks, Aurele
R063
original
aluminum
Never
gallons,
water
extremely
climb
never got up.
air.
under
you're
interested.
has
neutral
Aurele
R063
WALTER KLATT
912 performance
Post by WALTER KLATT » Sat Feb 18, 2012 10:12 am
Thanks, Aurele, that's very interesting. With my 0320 on amphibs, it takes a good headwind to get me off under 10 seconds. I guess its all about weight.
You mentioned 625 empty weight, and assume that is on wheels, which is still very light for a Rebel. Do you know what it is on floats?
And yes, send me the float pics directly.
Date: Wednesday, February 16, 2005 8:53 am
original
straight aluminum
hp. Never
gallons,
scared
the water
extremely
and climb
luck and
never got up.
the air. I
under
off
you're
interested.
this has
neutral
Aurele
R063
[mike.davis@dcsol.com]On Behalf Of
Aurele Lavigne
sight gauges.
will notice some
want it. Of course
throttle back.
the water in short
pilots babied these
engines too much.
Hope this helps,
Aurele
R063
if so would
cold and hot air
Date: 14/02/2005
14/02/2005>
IAN DONALDSON
912 performance
G'day Aurele
an
air box.
Ok I had always assumed that it got a lot of warm air from under the cowl. I
have never had a problem, but that is not to say that it could not happen.
Well, I would like to see the blueprint if you would like to find it and
send it over. I would appreciate that. When I found that the factory one
would not fit I did not bother anymore.
Regards
Ian Donaldson
