Pics of extra Hinge at aileron spade
Posted: Sat Feb 18, 2012 1:09 pm
by gerry
Was anyone able to find my pics ?? I am new to the site so not sure if I did
everything correct!
Gerry C-FISH
by Skytrucks
Gerry;
Your pictures turned out good, thanks for posting them.
Larry Luckinbill
S R 117 Moose
by Scott Aldrich
Gerry,
Yes, thank you!
Scott
Moose 174
gerry@dcsol.com
Sent: Wednesday, February 09, 2005 7:47 AM
Subject: Pics of extra Hinge at aileron spade
everything correct!
Gerry C-FISH
by Dick Shotwell
Gerry,
I found the pictures OK. Thanks. Now, I need to see comments on how
someone has figured out how to do this with the original MAM wing tips. Our
Moose was finished before the new drooped tips were available.
Dick Shotwell
Moose 096
N235DS
Twin Falls, ID
Sent: Wednesday, February 09, 2005 7:46 AM
did
everything correct!
Gerry C-FISH
by Ted Waltman
Dick,
Seems that there are couple of issues here. One as you state is how to
add the extra hinge on the original wing tips; the other point is that
older planes (e.g. mine) have the smaller aileron spade which doesn't
seem to have/cause the same cracking problem as newer models.
Ted
Dick Shotwell
Sent: Wednesday, February 09, 2005 9:29 PM
Subject: Re: Pics of extra Hinge at aileron spade
Gerry,
Our Moose was finished before the new drooped tips were available. Dick
Shotwell Moose 096 N235DS Twin Falls, ID
did
everything correct!
Gerry C-FISH
by gerry
Hi Dick, There is a fellow in Ontario who added the extra hinge on the non
droop tips by installing a phenolic bushing on the tip rib. He then installed
a "pin" on the aileron spade rib by using a bolt with long threads and a nut
on either side to hold it. When he puts the aileron on he slips the "pin"
into the phenolic bushing and then bolts the aileron to the remainding
hinges. He stated he did not have to cut any extra inspection covers this
way. I hope this makes some sense.
Gerry Moose 0097 C-FISH
On 2/9/2005 7:29 PM, DICKS@FILERTEL.COM wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Wed, 09 Feb 2005 19:32:03 -0900
-> Received: from relay2.av-mx.com ([137.118.16.124]) EHLO=relay0.av-mx.com
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 78131812; Wed, 09 Feb 2005 19:32:00 -0900
-> X-Virus-Scan-Time: 0
-> Received: from [137.118.16.60] (HELO mx2.av-mx.com)
-> by relay0.av-mx.com (CommuniGate Pro SMTP 4.2.7)
-> with SMTP id 46324832 for rebel-builders@dcsol.com; Wed, 09 Feb 2005
23:31:58 -0500
-> Received: (qmail 14753 invoked from network); 10 Feb 2005 04:31:58 -0000
-> Received: from unknown (HELO hppav) (dicks@filertel.com@208.187.108.230)
-> by 0 with SMTP; 10 Feb 2005 04:31:58 -0000
-> X-CLIENT-IP: 208.187.108.230
-> X-CLIENT-HOST: unknown
-> Message-ID: <001401c50f29$6cc12440$e66cbbd0@filertel.com>
-> From: "Dick Shotwell" <dicks@filertel.com>
-> References: <1107960406@dcsol.com>
-> Subject: Re: Pics of extra Hinge at aileron spade
-> Date: Wed, 9 Feb 2005 21:29:11 -0700
-> X-Orig-MIME-Version: 1.0
-> X-Orig-Content-Type: text/plain; charset="iso-8859-1"
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1409
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Gerry,
-> I found the pictures OK. Thanks. Now, I need to see comments on how
-> someone has figured out how to do this with the original MAM wing tips.
Our
-> Moose was finished before the new drooped tips were available.
-> Dick Shotwell
-> Moose 096
-> N235DS
-> Twin Falls, ID
-> From: <gerry@dcsol.com>
-> Sent: Wednesday, February 09, 2005 7:46 AM
-> Subject: Pics of extra Hinge at aileron spade
-> > Was anyone able to find my pics ?? I am new to the site so not sure if I
-> did
-> > everything correct!
-> > Gerry C-FISH
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
by Dick Shotwell
Thanks Gerry. I can imagine basically what he did. I am wondering what the
phenolic bushing is. I wonder how he installed it in the tip rib without
having an inspection hole in the tip. The type of bushing will probably
answer that question. Can the fellow in Ontario be contacted to answer some
questions?
Dick Shotwell
Moose 096
N235DS
Twin Falls, ID
Sent: Thursday, February 10, 2005 6:55 AM
installed
nut
23:31:58 -0500
04:31:58 -0000
-> X-Priority: 3
-> Gerry,
Our
-> Dick Shotwell
-> Moose 096
-> N235DS
-> Twin Falls, ID
if I
-> did
-> > Gerry C-FISH
