Spar cracking at Aileron spade
Posted: Sat Feb 18, 2012 1:09 pm
by gerry
I have installed another hinge at the outboard rib of the aileron spade and
the inboard rib of the wing tip. This is quite a bit less work than the mods
requested by MAM. I believe that this is a better fix as the spade is now
supported on both sides. This fix does not require removal of the wing tip or
any skins.You have to remove the aileron and using a laser lite sight thru
the hinges to get the pivot point for the AIL25 bushing .Rivet the bushing in
place. Then blue the end rib of the aileron spade and replace the aileron. I
have the wide spades so I cut an extra 2 1/4" inspection hole in the spade
and in the fiberglass tip.Install a AIL26 steel bushing into the brass
bushing and then using a 1/4" piece of drill rod sharpened at one end slide
it thru the bushing using the new inspection hole in the wing tip and mark
the pivot point on the aileron spade rib. Remove the aileron and drill and
bush as above.I installed a .040" doubler on both ribs as well for extra
support. Now you have an extra hinge supporting the aileron spade. I am sure
I am not the first to do this mod but I have pics if anyone is interested.
Gerry C-FISH
pilobear@hotmail.com
by Al Paxhia
Hi Gerry,
I would love to see pictures. I have not done the mod to the wing yet.
Al
Sent: Saturday, February 05, 2005 12:49 PM
Subject: Spar cracking at Aileron spade
mods
or
in
slide
sure
interested.
Gerry C-FISH
by Dick Shotwell
I too would like to see the pictures Gerry. Like Al, I have not yet done
the MAM mod.
Dick Shotwell
Moose 096
N235DS
Twin Falls, ID
Sent: Saturday, February 05, 2005 13:49 PM
mods
or
in
slide
sure
interested.
Gerry C-FISH
by Ralph Baker
Gerry,
Is your "added bearing" fix for the Moose or Elite. We are building an
Elite and I don't remember seeing anything on the MAM site or Rebel list
regarding spar cracking.
Rallph Baker
by murray
Yes would you send the pic's or post them
Thanks Murray
Murphymoose@shaw.ca
On 2/5/2005 11:49 AM, GERRY wrote to MOOSE BUILDERS:
-> I have installed another hinge at the outboard rib of the aileron spade
-> the inboard rib of the wing tip. This is quite a bit less work than the
mods
-> requested by MAM. I believe that this is a better fix as the spade is now
-> supported on both sides. This fix does not require removal of the wing tip
or
-> any skins.You have to remove the aileron and using a laser lite sight thru
-> the hinges to get the pivot point for the AIL25 bushing .Rivet the bushing
in
-> place. Then blue the end rib of the aileron spade and replace the
aileron. I
-> have the wide spades so I cut an extra 2 1/4" inspection hole in the spade
-> and in the fiberglass tip.Install a AIL26 steel bushing into the brass
-> bushing and then using a 1/4" piece of drill rod sharpened at one end
slide
-> it thru the bushing using the new inspection hole in the wing tip and mark
-> the pivot point on the aileron spade rib. Remove the aileron and drill and
-> bush as above.I installed a .040" doubler on both ribs as well for extra
-> support. Now you have an extra hinge supporting the aileron spade. I am
sure
-> I am not the first to do this mod but I have pics if anyone is interested.
-> Gerry C-FISH
-> pilobear@hotmail.com
by Skytrucks
Gerry;
Thanks for the information, I also would like to see the pictures of
your mod.
Larry Luckinbill
by David Ricker
Hi Guys
I think we would like to see the pics posted to the archive and given the
similarity I think there is a growing group of Elite builders that would be
interested to see what the mod looks like too.
elite583.cjb.net
Thanks Murray
Murphymoose@shaw.ca
mods
or
in
aileron. I
slide
sure
-> Gerry C-FISH
David A. Ricker
Fall River, Nova Scotia
Canada
by gerry
This fix is on my Moose with droop tips . As I have not flown yet I do not
have any cracking. I looked at MAM's fix and talked to a gentleman in Ontario
who did some what the same as I have and he stated he has not had a problem
since. Not sure if this "fix" would be good for the elite but I would have to
assume so. The problem seems to be the spade hanging out past the last
hinge . With an extra hinge point the spade no longer hangs out as it is
Gerry
On 1/5/1996 4:03 AM, REBAKER@FTC-I.NET wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Sat, 05 Feb 2005 17:00:03 -0900
-> Received: from smtp01.infoave.net ([165.166.0.26]) EHLO=SMTP01.INFOAVE.NET
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 511158578; Sat, 05 Feb 2005 17:00:01 -0900
-> Received: from oemcomputer ([216.218.101.199])
-> by SMTP00.InfoAve.Net (PMDF V6.2-X31 #30986)
-> with SMTP id <01LKGJGHSMWW9DF8ZG@SMTP00.InfoAve.Net> for
-> rebel-builders@dcsol.com; Sat, 05 Feb 2005 20:58:33 -0500 (EST)
-> Date: Fri, 05 Jan 1996 08:03:09 -0500
-> From: Ralph Baker <rebaker@ftc-i.net>
-> Subject: Spar cracking at Aileron spade
-> Message-id: <001401badb6e$2a566320$c765dad8@oemcomputer>
-> X-Orig-MIME-version: 1.0
-> X-MIMEOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
-> X-Mailer: Microsoft Outlook Express 6.00.2800.1409
-> X-Orig-Content-type: multipart/alternative; boundary="----
=_NextPart_000_0011_01BADB44.406C2C00"
-> X-Priority: 3
-> X-MSMail-priority: Normal
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Gerry,
-> Is your "added bearing" fix for the Moose or Elite. We are building an
-> Elite and I don't remember seeing anything on the MAM site or Rebel list
-> regarding spar cracking.
-> Thanks,
-> Rallph Baker
