Login problem
Login problem
Post by Mike Davis » Sat Feb 18, 2012 10:01 am
Thought I'd go ahead and respond to the list in case anybody else had
problems with this...
When you click on the link to the address book, it will come up with the
listings by default. To create your own account, or log in with that
account once it's created you must do the following...
Near the top where it lists Upcoming Birthdays it says, "You are not logged
in. Log in here.", click on "Log in here."
I will now display a page with fields for a username and password... once
your account has been created, this is where you put this information, but
if this is your first time and you need to create your account, click on
"register/lost password" beneath the password field. This will load a form
allowing you to create a new account. When your account has been created
the system will send you a confirmation e-mail with a link in it to activate
the account. This ensures that the holder of the e-mail address used to
create the account is the one doing so. When you click on this link it will
load the site giving you a message that your account has been activated
along with a link to take you back to the login screen, where you can now
fill in the username and password fields to log in.
Hope this helps.
To: <mike.davis@dcsol.com>
Sent: Friday, January 14, 2005 7:54 PM
Subject: Login problem
Mike,
How do I log in to the Rebel Builders Address Book? When I try to
establish a User Name and Password within the address book
application , I get the dialog response "Login Incorrect". What am I doing
wrong?
Jack Joos
email: lawsontj@att.net
