Rebel Wiring Routing Plan
Posted: Sat Feb 18, 2012 12:58 pm
Greetings Rebel Group:
I am returning to work on the Rebel after a lengthy break from drills
and deburring tools and need to get some stuff sorted out before I
commence! I apologize in advance for the long post, but hopefully my
questions may help someone with wire routing questions in the future as
I have now.
I am building a Rebel with the standard firewall and plan to install an
O320-D2A (160hp). Electrical will be day/night VFR. Basic fuselage is
complete, but I have not installed the interior forward inside floor
skin and corner wraps yet. If my plan is viable, I would like to run the
wiring from the tailcone, under the corner wrap skin starting at "A" and
"F" bulkheads, forward to their respective termination points. My main
thrust is safety and to keep the floors clean with minimal wiring and
fuel lines exposed. Note: Fuel line routing questions will be addressed
in my next post.
The Wiring Routing Plan:
Since the starter is on the left side of the engine, my plan is to mount
an Odyssey PC680 at the LEFT aft ledge between "D" and "E" bulkhead (as
far aft as possible, above the finished floor). Wiring will then route
forward, just above the corner wrap ledges, through all bulkheads. Once
I get forward of bulkhead "A", the wire will dive down through the ledge
between "A" and "F" (into flexible conduit), under the corner wrap area,
running forward through the factory "mouse holes" and through the lower
1/2 inch holes at both FUS-2
I have now.
in my next post.
