Rebel trim tab throw
Posted: Sat Feb 18, 2012 9:54 am
I got my trim servo installed with nutplates and the pushrod all fitted. I
only drilled one hole in the horn, right at the end. As currently adjusted,
anticipating a need for more nose up trim than nose down, I have about 1" of
trim tab down throw at the trailing edge, and about 5/8" up. Will this be
enough, or do I need to drill another hole further down the horn? Problem is
that I had to "scallop" out the edge of the horn quite a bit for clevis
clearance so if I make another hole it will have to be quite far down.
