Drilling holes
Drilling holes
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from ne.com.au (tc1-60.ne.com.au [203.13.72.252]) by
redback.ne.com.au (8.8.7/8.7.3) with ESMTP id VAA30619 for
<murphy-rebel@dcsol.com>; Sun, 5 Sep 1999 21:57:49 +1000
Message-ID: <37D25B36.31FAD143@ne.com.au>
Date: Sun, 05 Sep 1999 21:59:50 +1000
X-Mailer: Mozilla 4.05 [en] (Win95; I)
MIME-Version: 1.0
To: "(Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Drilling holes
G'day from Australia
This might seem a stupid question, but what is a good way from stopping
the drill chuck from marking the aluminum when the bit breaks through?
Is there something that I can put on the drill bit?
Regards and thanks
Ian Donaldson
Drilling holes
Received: from [154.5.73.117] (helo=ip117.toronto7.dialup.canada.psi.net)
by smtp2.interramp.com with smtp (Exim 1.90 #1)
for murphy-rebel@dcsol.com
id 11NdSX-0005hr-00; Sun, 5 Sep 1999 10:39:57 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: Re: Drilling holes
Message-Id: <E11NdSX-0005hr-00@smtp2.interramp.com>
Date: Sun, 5 Sep 1999 10:39:57 -0400
There are no dumb questions ! (some of the answers, well ....) :-)
That's what this list is for - we're here to help others to avoid OUR
mistakes !
There is a gadget called a drill stop that fits on the bit that will
stop the drill from continueing down past it. A simple, cheap solution
is to slip a piece of clear fuel line over the bit, leaving just 1/4"
exposed at the biting end.
If you have to push hard enough that the drill chuck is hitting the
skins, it sounds like you are WAY overdue for a new bit !! The cheapest
thing you can do to save yourself time, and get a nicer Rebel is:
THROW AWAY the old drill bits, as soon as they require a push to
work properly !! Builders here have found that, if you use a high-speed
(4,500 - 6,000 rpm) drill, and sharp bits, you can ALMOST eliminate the
tedious job of de-burring, AND get nicer holes. These drills are available
in both air driven and electric, although you will have to search for
the electric models...
Folks have not had much success re-sharpening these small bits -
they never seem to work as well, and are fairly cheap to replace, so
it's not worth the effort.
-----------------------------orig.--------------------------------------
Regards and thanks
Ian Donaldson
Drilling holes
Received: from albedo.net (ppp129.albedo.net [206.51.22.148])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id RAA02663
for <murphy-rebel@dcsol.com>; Sun, 5 Sep 1999 17:52:40 -0400
Message-ID: <37D2E559.98DD0CE1@albedo.net>
Date: Sun, 05 Sep 1999 17:49:13 -0400
X-Mailer: Mozilla 4.08 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
References: <E11NdSX-0005hr-00@smtp2.interramp.com>
Man you are full of info these days Bob.
Those oldy Goldy Matco wheels do indeed only have a 680 static rating which
assume must be lbs :(
Ian, FWIW I also found this useful when drilling the wing stringers to make
sure
I didn't go through and nick the back side of the "J" but the hose does like
collect aluminum chips and scratch the surface. A $3. drill stops was a
little
better. They include a spring and a hard plastic rounded stop that doesn't
collect chips. Leaving the plastic coating on the aluminum as long as
possible
also helps.
Gee and I thought I was doing well to upgrade from an 1800 to a 2800rpm
drill!
Anyway you might also try the 135 degree split point bits for the #40 size.
Very
nice for the first small hole. Less than $1. ea. by the dozen from DoAll or
an
industrial supplier. A dozen HSS ones last me for several thousand holes.
The
higher quality cobalt ones last even longer.
Drilling holes
Received: from [154.5.72.127] (helo=ip127.toronto6.dialup.canada.psi.net)
by smtp1.interramp.com with smtp (Exim 1.90 #1)
id 11Nzfp-00024P-00; Mon, 6 Sep 1999 10:23:10 -0400
Mime-Version: 1.0
Message-Id: <E11Nzfp-00024P-00@smtp1.interramp.com>
Date: Mon, 6 Sep 1999 10:23:10 -0400
Sounds interesting ! Could you bring a couple of samples to the next
meeting ??
Thanks ! .....bobp
-------------------------------orig.---------------------------------------
sure
like to
little
possible
also helps.
drill!
Very
an
The
Drilling holes
Received: from the-benson-s
(216-164-134-26.s280.tnt3.lnhva.md.dialup.rcn.com
[216.164.134.26])
by smtp3.erols.com (8.8.8/8.8.5) with SMTP id TAA19249
for <murphy-rebel@dcsol.com>; Mon, 6 Sep 1999 19:55:21 -0400 (EDT)
Message-ID: <007d01bef8c2$deeefa20$ec83a4d8@the-benson-s>
Date: Mon, 6 Sep 1999 19:52:24 -0400
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Black & Decker has both the "Pilot Point" and "Split Point" drill bits.
Using those drill bits I very seldom have to use the center punch.
Date: Monday, September 06, 1999 10:23 AM
size.
meeting ??
Thanks ! .....bobp
which I
make
sure
like to
little
possible
also helps.
drill!
size.
Very
or an
The
