elevator MOOSE
Posted: Sat Feb 18, 2012 9:49 am
Yes, there was a problem with clearance of the V and the rear fin post after
the .063 spar caps where installed for the Moose upgrades. Lucky me was the
guy that found this out...after closing the elevator for the third time. Was
decided that if you trim the elevator skin off at the existing holes and
move the ribs outboard all would be well. MAM retooled to open the V in a
larger angle to get a similar clearance. I don't remember the measurements
to determine if you have an old elevator skin or a new one. Dimensions are
in the archives somewhere...where I gave the inner width and outer width so
you know if you already have a wider one or a newer one.
If you can't find the dimensions in the next day or so let me know and I
will open up the marine container mine is in and measure the widths again.
Sent: Wednesday, December 08, 2004 4:19 PM
Subject: elevator
Subject: elevator
I am ready to rivett the elevator together with the MAM mod ,was there a
problem with clearences with the V traveling near the fin??? As well the
stabilizer and fin spar had mod doublers to the spars , what do you guys
feel that maybe the elevator would required beefed up?? it would be the
time to do it!!
