FUS-30 & MATCO Brake Problems
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from the-benson-s
(216-164-138-164.s164.tnt5.lnhva.md.dialup.rcn.com
[216.164.138.164])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id XAA06777;
Tue, 31 Aug 1999 23:18:25 -0400 (EDT)
Message-ID: <006a01bef427$b9d812c0$ce84a4d8@the-benson-s>
Cc: "Dave Ritland" <drit@erols.com>
Subject: Re: FUS-30 & MATCO Brake Problems
Date: Tue, 31 Aug 1999 23:11:45 -0400
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_0067_01BEF406.31DB7680"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
This is a multi-part message in MIME format.
------=_NextPart_000_0067_01BEF406.31DB7680
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Bob: FUS-49 is the tailspring bulkhead. FUS-30 is the tail wrap that =
is cracking etc.on some Rebels.
I have the silver Matco wheels and the axles are the same diameter. =20
I am planning to attend the meeting 0n the 19th. I will bring pictures =
and a drawing of the spring gear mod that Allister was describing in =
todays message "Re: spring gear strengthening"
Content-Type: text/html;
<HTML>
<HEAD>
<META content=3Dtext/html;charset=3Diso-8859-1 =
http-equiv=3DContent-Type>
<META content=3D'"MSHTML 4.72.3616.1301"' name=3DGENERATOR>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT color=3D#000000 size=3D2>Bob:&nbsp; FUS-49 is the tailspring=20
bulkhead.&nbsp; FUS-30 is the tail wrap that is cracking etc.on some=20
Rebels.</FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT color=3D#000000 size=3D2>I have the silver Matco wheels and =
the axles are=20
the same diameter.&nbsp; </FONT></DIV>
<DIV><FONT color=3D#000000 size=3D2>I am planning to attend the meeting =
0n the=20
19th.&nbsp; I will bring pictures and a drawing of the spring gear mod =
that=20
Allister was describing in todays message "Re: spring gear=20
strengthening"</FONT></DIV></BODY></HTML>
------=_NextPart_000_0067_01BEF406.31DB7680--
Received: from albedo.net (ppp126.albedo.net [206.51.22.145])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id SAA24226
for <murphy-rebel@dcsol.com>; Wed, 1 Sep 1999 18:27:01 -0400
Message-ID: <37CDA7B1.6F4BA4F9@albedo.net>
Date: Wed, 01 Sep 1999 18:24:49 -0400
X-Mailer: Mozilla 4.08 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
References: <E11MCsN-0004f6-00@mail4.toronto.istar.net>
I have the gold 6.00x6 wheels installed and hate to toss them since the
machine
will be going on floats after a year or two. I know the matco brakes are
weak
but I think I can live with that. Am I fooling myself?
Is there any longevity problem with the Matco units or anything in
particular to
watch for? The brake discs on these wheels bolt to 3 tabs that are welded to
rims .
The 1650# gear upgrade has been done so the axles are 7/8".
R119
Received: from BILNEWKIRK@aol.com
by imo17.mx.aol.com (mail_out_v22.4.) id bMERa09417 (3962)
for <murphy-rebel@dcsol.com>; Thu, 2 Sep 1999 13:30:28 -0400 (EDT)
Message-ID: <2252df5d.25000e34@aol.com>
Date: Thu, 2 Sep 1999 13:30:28 EDT
MIME-Version: 1.0
X-Mailer: AOL 4.0 for Windows 95 sub 22
YOU MENTIONED RELOCATING THE BOTTOM OF THE BRAKE PEDAL CYLINDERS. IF THIS
IMPROVES BRAKE ACTION, I WOULD BE INTERESTED IN MORE DETAILS. I HAVE THE
NEWER STYLE MURPHY BRAKES.
BILL NEWKIRK
Received: from dialup.voyager.co.nz (ts1p09.net.ashburton.voyager.co.nz
[203.21.25.173])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with SMTP id IAA15551
for <murphy-rebel@dcsol.com>; Fri, 3 Sep 1999 08:32:58 +1200 (NZST)
Message-ID: <001001bef582$4293f920$ad1915cb@dialup.voyager.co.nz>
Date: Fri, 3 Sep 1999 08:32:17 +1200
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Hi Bill,
There was a session on this in this forum not so long ago, it should be in
the archives.
It simply involves making a new bracket to mount the bottom of the brake
cylinders on the floor in front of the rudder pedal mounting. As the rudder
pedal is moved forward and backward the brake cylinder should remain
parrallel to it.
This ensures the brake pedal remains at a constant angle at any rudder
delection. ( Great for stopping ground loops!!!)
It is a very good mod.
Alister
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Friday, September 03, 1999 5:31 AM
BILL NEWKIRK
Received: from [154.5.73.235] (helo=ip235.toronto7.dialup.canada.psi.net)
by smtp2.interramp.com with smtp (Exim 1.90 #1)
for murphy-rebel@dcsol.com
id 11MkQK-0001hV-00; Thu, 2 Sep 1999 23:54:01 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Message-Id: <E11MkQK-0001hV-00@smtp2.interramp.com>
Date: Thu, 2 Sep 1999 23:54:01 -0400
As I recall, the GOLD Matcos were only rated for 600 Lb. load (!!!).
There have been a few cases of the rims splitting on heavier Rebels.
As for the effectiveness of the small Matco brakes - it's mostly wishful
thinking. They would NOT hold a Subaru - powered Rebel with much more than
idle power. There is virtually NO effectiveness in trying to turn sharply
- there wouldn't be enough braking force to pop out the kick-out tailwheel !
Slowing down after landing ... well, there's more drag from leaving the
flaps down than from the brakes !
The Gold Matco's were only marginally suitable for Renegades,
Mavericks,
and ultra-light Rebels....
You probably should talk to Angus McKenzie at the next builders meeting
- he just replaced his Silver Matcos after less than 50 hours flying. I
think the disk retainers cracked ... but he can give you the full story.
One consideration might be the difficulty he encountered in converting
to the Murphy wheels after-the-fact....
It might be worth a phone call to Colleen at Murphy regarding a trade-in
on the Matcos - I'm sure they don't want anybody damaging their new Rebel.
---------------------------orig.------------------------------------------
machine
weak
particular to
to the
rims .
R119
