R-263
George Coy
R-263
Post by George Coy » Sat Feb 18, 2012 9:49 am
We have some information on the R-263 up on our web site now. We only have
preliminary info at this time. The engineering team has finished most of the
drawings for the engine and some of the parts are under construction. It is
planned that the prototype engines will be made of machined from billet
parts. Production engines will have castings and forgings. The tooling will
be developed after the prototype engines have been flown for several hundred
hours. That is why production engines are scheduled for first quarter of
2006.
The following is preliminary info:
1. We plan to use Lycoming intake and exhaust valves, springs keepers etc.
to make parts easily available and avoid developing new valve sources.
2. We plan to use the Elliston throttle body system.
3. We will use a SkyTek starter and a 35 Amp belt driven Niagara air parts
alternator. The alternator and starter will be on the accessory case on the
back of the engine. It will use a standard Lycoming style diaphragm fuel
pump as well.
4. The cylinder barrels and heads will be basically the same as they are now
producing on the M14P.
5. The initial engines will use the "lunch box" style Bendix magnetos.
Savage magneto is building some up for us now. Future engines may have
electronic ignition depending on the .
6. The engine will be designed to use standard fixed pitch metal props and
will turn in the normal western direction.
We will develop the 125 hp version first. The 150 hp version will be the
same engine but geared with the crankshaft turning about 3200 rpm max. The
gear box will be similar to the M14P. The 180 hp version will be geared and
supercharged. The initial design will make provisions to add the
supercharger to he intake plenum.
R-263 125 Hp Engine Specifications
Number of Cylinders --------------------------- 5
Cooling System ------------------------------- Air
Bore ------------------------------------------ 4.25 in.
Stroke ---------------------------------------- 3.7 in
Displacement ---------------------------------- 263 in.3
Sense of Rotation ----------------------------- Clockwise
Compression Ratio ----------------------------- 7:1
Starting System ------------------------------- Electric
Ignition system ------------------------------- Dual Magnetos
Fuel System ----------------------------------- Fuel Injection
Oil System ------------------------------------ Pressure and Scavenge pump
Max Power ------------------------------------- 125 HP @ 2700 RPM
Max Speed ------------------------------------- 3200 RPM
Idle Speed ------------------------------------ 800 RPM
Diameter -------------------------------------- 33 in.
Length ---------------------------------------- 27 in
Dry Weight ------------------------------------ 220 lbs.
Fuel ------------------------------------------ 80/87 min or Auto Fuel
Propeller Flange ------------------------------ SAE #2
George Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Web Site www.gesoco.com
e-mail George@gesoco.com
Sent: Thursday, December 02, 2004 9:07 PM
Subject: Re: R-263 (was metal ...the rest of the story)
George is still staying quiet about it though! :o))
What's happening with this little gem George?????
Come'on do some "advertising" here!!
Sent: Thursday, December 02, 2004 8:44 PM
Subject: RE: R-263 (was metal ...the rest of the story)
When Wayne I think mentioned the M14's little brother the other day, I
didn't
see it at the web site. But see it now and am thinking I believe in love
at
first site.
-Ben/ R496
bransom
R-263
Post by bransom » Sat Feb 18, 2012 9:49 am
I've not paid attention to the radials, but am suddenly interested. I've got
a few questions and then will try to let it rest so George/Gesoco can build
an engine and I can build an airframe. :)
How do radials compare to horizontal opposed engines wrt vibration?
Obviously 5 pulses is better than 4 but am curious if any thoughts/comoments
here.
Is the gear reduction or supercharger considered to require more maintenance
or shorter TBO than the rest of the engine? Any answers based on M14
experience appreaciated here.
Undoubtedly the gear reduction and supercharger will add weight. Any rough
idea how much on either at this point? (The 220lbs of the small variant is
darned appealing.)
-Ben/ 496R
2006.
pump as well.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
didn't
at
first site.
-Ben/ R496
George Coy
R-263
Ben,
1. Radials tend to be smoother as they fire in a circle and not back and
forth. It should be smoother with 2.5 power strokes per revolution instead
of two.
2. There should not be any more maintenance for the supercharger or the
gears reduction unit. A shorter cylinder life may result due to the higher
RPM of the crankshaft.
3. We do not know the weight difference yet. It should not be too much as
the original design will have provision for them.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
bransom@dcsol.com
Sent: Friday, December 03, 2004 3:02 PM
Subject: RE: R-263
got
here.
darned appealing.)
-Ben/ 496R
is
will
hundred
2006.
pump as well.
now
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
didn't
love
at
first site.
-Ben/ R496
bransom
R-263
Thanks for the info George. The power to weight ratio with this engine could
be darned exciting.
-Ben
Ben,
of two.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
bransom@dcsol.com
Subject: RE: R-263
got
here.
darned appealing.)
-Ben/ 496R
is
will
hundred
2006.
pump as well.
now
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
didn't
love
at
first site.
-Ben/ R496
