SR Chevy engine mount and Cowl
Posted: Sat Feb 18, 2012 12:46 pm
My engine mount is nearing completion. I just uploaded two new pictures to
the SR engine section. Finger straps and gussets still need to be added
here and there. Also, a horizontal tube between the two upper engine mount
points on the firewall will be added to stiffen the mount. If you pull the
upper bolt on one side as it is now the mount still has a lot of flex.
Instead of relying on the channel riveted to the firewall to account for
this we decided we wanted the mount to be stiff on it's own.
I discussed Ken's comments with my mount builder and I think most of Ken's
concerns are addressed by the cross pieces that are now visible in the most
recent pics that I uploaded. Downward forces on the rear mount points are
accounted for with the tube from the upper fuselage point to the point below
the rear engine mount point. Outward forces on the rear mount point are
accounted for with the cross pieces at the lower rear of the mount that
weren't in the original pics. The rear mount points are now the apex of a
four point pyramid. Although I know adding a tube from the top firewall
points to the rear engine mount points would add strength, I'm not sure it
is necessary with the current configuration. The tube in it's current
position definitely has less of a bending moment on it then a tube going
directly from the firewall points to the engine mount points would. I'm
going to take one last look at it this weekend and make a final decision
about whether or not to add another tube. Thanks again Ken for your input.
I am now looking ahead to the cowling. I wonder if Bob and others could
tell me more about the channels used to begin building the four door cowl?
I have asked Murphy to quote me on three channels just like the one on the
firewall between the upper mount points but five feet in length. I was
thinking that I could use those as the left, right, and upper channels to
start the four door cowl idea. I think they are 3-inch channels with 1-inch
flanges made from something like 0.040 or 0.062 aluminum. (I'm not in my
shop - just guessing from memory). Next, I still want to find an
off-the-shelf nose bowl that would work. Any ideas on that? Lastly, I'm
hoping that I can simply form the cowl skins by hand somehow since I don't
have a sheet metal roller. Any ideas on that? HELP! Thanks
SR044
SR044
