I went with compression blocks glued in place.
I don't know how you'd get the rear bolt in once the floor corner wraps are
in place. The nut goes in via the inspection cutout in the door sill.
Also, your fuel line is probably going to wind up coming out above the
forward bolt, so again you'd have a hard time getting the bolt in from
above.
Al
Sent: Tuesday, November 23, 2004 5:11 PM
Subject: RE: Elite Spring Gear crush tubes & compression block question
whereThanks Wayne
I'll go for a few blobs of Sikaflex
Nig
Sent: 23 November 2004 18:18
Subject: Fw: Elite Spring Gear crush tubes & compression block question
The word "crate" is of course supposed to be create!
Sent: Tuesday, November 23, 2004 1:12 PM
Subject: Re: Elite Spring Gear crush tubes & compression block question
Nig, one more before I get back in the shop! I Sikaflexed the blocks in
place. Any thing..proseal, RTV etc would do.
The single 3/8" leg retainer bolt I put the nut on the outsid.....
bendingit's easy to properly torque. The saddle bolts probably have some merrit
going in from below as if you stripped a nut in a hard arrival the
propbolt might crate enough friction to hold you up somewhat to negate a
overstrike.....although it definitely will add a bit of work to switching
andto the float brackets like you have envisioned!
Sent: Tuesday, November 23, 2004 12:55 PM
Subject: Elite Spring Gear crush tubes & compression block question
Hi All
Just a quick question about the spring gear compression tubes SG-10
thethecompression block SG-5 that surround the AN5 and AN6 bolts holding ongear legs inside the FUS 5 carrythrough's.
The manual shows the bolts going in from underneath, with the nut on
bolttotop.
My question is has anyone had a problem when changing from spring gearcompressionfloats or the other way round and whilst the bolt is removed thetubes or block move and cannot be relocated around the bolt. If the
floorlesswasmounted from above the nut could be removed and the bolt left more orcorrectly.in place lying through the fuselage so the tubes remain locatedThe other option may be to "glue" the tubes in position before the
isrivetriveted down ?
Ideas, or am I just worrying about a non event (hopefully starting tothe floor down later tomorrow so thought I'd check :-)
Nigel
745E
