Strengthening for 0320
Posted: Fri Feb 17, 2012 8:26 pm
by Mike Davis
Received: from [205.163.8.199] (drk.cts.com [205.163.8.199])
by neko.cts.com (8.9.3/8.9.3) with ESMTP id VAA29102
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 21:44:14 -0700 (PDT)
X-Sender: drk@crash.cts.com
Message-Id: <v04003a01b3e36a0dbf77@[205.163.8.199]>
In-Reply-To: <001a01beea8a$4657d3e0$ac1915cb@dialup.voyager.co.nz>
Mime-Version: 1.0
Date: Fri, 20 Aug 1999 21:44:13 +0100
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: Re: Strengthening for 0320
Alister,
We sure enjoy hearing from you and your "field testing" experiences.
I also will be installing the spring gear with an O320 engine and would
very much like to incorporate some of the enhancements that seem reasonable
while I am in the construction stage.
Do you have the standard or Elite style curved instrument panel? How thick
was the upper panel that cracked?
If you would be so kind as to summarize the "mods" you have determined to
be necessary I would be most appreciative.
Thanks again for your posts.
Dave Klimas
Ramona, CA
Rebel #472
Brian,
The flying is going just great, I have clocked up over 160hrs
now. What a neat little aircraft!
Even with a cruise prop I can pull very big loads out of very small areas,
very useful aircraft.
The strengthening mods I did around the gear area are working really good,
no problems in that area now.
I found another problem though.
Cracks started to appear on the instrument panel, on checking, they were
coming from a mis-directed load path. When taxiing ( when heavy) on rough
ground the panel in front and on top of the instrument panel used to pant
(flex) on either side just in front of where the instrument panel bends. It
finally cracked in this area. ( this was hidden by upholstery)
I had to remove the windscreen and reinforce the area including the top
engine mounts.
I have no doubt that the problems I have experienced come from hanging off
heavier and heavier motors without increasing the skin thickness and design
up front to compensate. ( Didn't the Rebel start with a 582?)
I also operate off sometimes very rough strips. ( a lot off these were put
in in the old deer meat recovery days, they are cut out of riverbeds and
are
ROUGH!) Murphy says ' sorry, but it appears you are doing the forward field
testing for these types of operations', They are probably right, they say
that over there that the majority of Rebels that operate in the outback
would be on floats. Floats can be very hard on a fuse as well but the load
paths are very different.
However, I really do feel that I am getting to the point where I am on top
of this ( I hope those aren't famous last words!).
If you are running an 0320 and spring gear and intend to operate out of
unimproved strips it would pay to have a think about it.
Alister
Date: Friday, August 20, 1999 1:17 AM
Subject: Re: c of g
Hi Alister
Sorry if I confused/misled you about my empty C of G. With 2 pilots & 3/4
fuel my the C of G is
about 16". My empty C of G is 11.6".
How is the flying going? Spring gear OK?
Best Regards
Brian #328R
:08 PM 19/08/99 +1200, you wrote:
Hi Brian,
Could you confirn that your C of G is 16" empty.
That seems a long way back before you even begin to load it.
Alister
Date: Thursday, August 19, 1999 2:36 PM
Subject: Re: c of g
have
movement
factory
firewall rear
weight,
weight. big, motorcycle
up
it
would
have
softer
ANYTHING
will
flights,
tied
UP
lots.
be
g
wheel
an
0320 position
should
be
all,
is
any case
have
16.8"
and Even
adjust
on
experience
meeting
in
how
engine back
build
back.
g
tail. *----------------------------------------------------*
by Mike Davis
Received: from dialup.voyager.co.nz (ts1p04.net.ashburton.voyager.co.nz
[203.21.25.168])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with SMTP id UAA09122
for <murphy-rebel@dcsol.com>; Sun, 22 Aug 1999 20:24:45 +1200 (NZST)
Message-ID: <003e01beec77$b658f860$a81915cb@dialup.voyager.co.nz>
Date: Sun, 22 Aug 1999 20:23:25 +1200
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.5
Hi Dave,
These mods are not so much mods for mods sake, but were done because they
were essential. If we had not done them things would have come to bits by
now!
1/ Front lower rolled corners replaced with 32 thou.
Where rolled corner meets front side panel C channel placed fore and aft to
stiffen area and stop panting (flexing), two rows of rivets there.
2/ Solid aluminum blocks milled and inserted in ends of all carrythroughs
(about 2 1/4" long & tapered a little
on the ends to stop stress points forming). the three AN 3 bolts in this
area were replaced by 3 long AN 4 bolts passing right through the whole
lot. We replaced the outer gear attach bolts with 3/8" and the main inner
bolt with 7/16" ( I would consider that last bit optional).
3/ Replace Fus 26 with 32 thou.
We replaced Fus 35 with one with wider flanges to accept two rows of rivets.
( optional)
4/ double pitch door post all the way up, the door post is wide enough to
'stagger' the rivets fore and aft a little.
5/ Complete Murphy's Float fix mod.
C channel between engine mount should be heavier rather than lighter.
6/ Top engine mount doubler removed and replaced with a C channel ( top hat
would be more effective) on the inside right back to the witches hat . We
also placed a larger flat 32 thou doubler on the outside as well.
7/ Front upper panel ( Fus 8) is very light. the weak spot appears to be
just in front of where the instrument panel bends backwards to meet the door
post. A triangular 32 thou. doubler installed on either side in this
position will do the trick. A stiffener across the middle of this top panel
should also be considered, it is very light.
8/ A doubler should be placed under the tail wheel attach bulkhead back to
the tail post as described recently in this forum. This falls to bits quite
quickly.
That just about covers it!! All these mods are not just my ideas but have
been looked at by very experienced aircraft engineers over here and were
necessary to carry on with safe operations. Other builders over here are
incorporating these mods as they go.
I do stress this is a Rebel with an 0320 ( heavier motor, which is a lot of
the problem) and spring gear (different load paths to
bungee) and is being operated on unimproved strips.
Other Rebels operated in a different manner may not show the same symptoms.
Hope this is of interest.
Alister
Date: Saturday, August 21, 1999 4:44 PM
Alister,
Dave Klimas
Ramona, CA
Rebel #472
Brian,
It
engine mounts.
design
are
field
Alister
Subject: Re: c of g
Hi Alister
3/4
Best Regards
Brian #328R
have
movement
wheels
factory
heard
weight,
up
keeping
it
have
softer
will
flights,
lots.
would
be
g
an
should
all,
is
course,
forward
have
16.8"
all.
adjust
on
experience
meeting
how
build
g
by Mike Davis
Received: from albedo.net (ppp152.albedo.net [206.51.22.171])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id IAA17483
for <murphy-rebel@dcsol.com>; Sun, 22 Aug 1999 08:51:47 -0400
Message-ID: <37BFF1AA.5BE3549D@albedo.net>
Date: Sun, 22 Aug 1999 08:48:42 -0400
X-Mailer: Mozilla 4.08 [en] (Win95; I)
MIME-Version: 1.0
References: <003e01beec77$b658f860$a81915cb@dialup.voyager.co.nz>
Thanks for the detailed posting Alister. I hate it when you send them after
I've
completed the applicable section but food for thought is always good!
And congratulations on achieving liftoff Glenn. Appreciate the info. Please
let
us know how flight testing progresses if you can.
by Mike Davis
by usagi.cts.com (8.9.3/8.9.3) with ESMTP id TAA25315
for <murphy-rebel@dcsol.com>; Sun, 22 Aug 1999 19:44:12 -0700 (PDT)
Message-Id: <v04003a02b3e5ee4b8fee@[205.163.8.199]>
In-Reply-To: <003e01beec77$b658f860$a81915cb@dialup.voyager.co.nz>
Mime-Version: 1.0
Date: Sun, 22 Aug 1999 19:44:14 +0100
Hi Alister,
Thank you so much for taking the time to post your list of "mods" for us.
The Elite curved instrument panel I ordered for my Rebel came with a new 32
thou FUS-8; the original is 25 thou.
Once again, thank you.
Dave Klimas
Ramona, CA
Rebel #472
Hi Dave,
now!
rivets.
( optional)
door
quickly.
Alister
Alister,
reasonable
Dave Klimas
Ramona, CA
Rebel #472
snip<<<
by Mike Davis
Received: from dialup.voyager.co.nz (ts1p01.net.ashburton.voyager.co.nz
[203.21.25.165])
by callisto.net.voyager.co.nz (8.9.0/8.9.0) with SMTP id TAA08208
for <murphy-rebel@dcsol.com>; Mon, 23 Aug 1999 19:46:12 +1200 (NZST)
Message-ID: <000c01beed3b$7e48b4a0$a51915cb@dialup.voyager.co.nz>
Date: Mon, 23 Aug 1999 19:45:34 +1200
MIME-Version: 1.0
X-Priority: 3
Hi Dave,
The new heavier Fus 8 fitted on a curved panel for the Elite will tighten
things up nicely.
That must be an admission by Murphy that things needed looking at in that
area. They don't let on much do they!! Why don't they bulletin these things?
It would save a lot a trouble for unsuspecting builders further down the
track.
Alister
Date: Monday, August 23, 1999 2:44 PM
Hi Alister,
Dave Klimas
Ramona, CA
Rebel #472
Hi Dave,
now!
rivets.
( optional)
hat
door
panel
quite
quickly.
symptoms.
Alister
Alister,
reasonable
thick
Dave Klimas
Ramona, CA
Rebel #472
by Mike Davis
Received: from tim - 209.119.137.69 by email.msn.com with Microsoft SMTPSVC;
Mon, 23 Aug 1999 10:43:59 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel Builders List'" <murphy-rebel@dcsol.com>
Subject: RE: Strengthening for 0320
Date: Mon, 23 Aug 1999 10:46:19 -0700
Message-ID: <000401beed8f$a33f6660$14640a0a@tim>
MIME-Version: 1.0
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2314.1300
Importance: Normal
Return-Path: tlcarter@email.msn.com
Alister:
Can you elaborate a bit more on number 2 below?
Tim
Sent: Sunday, August 22, 1999 1:23 AM
Hi Dave,
now!
( optional)
quickly.
Alister
Alister,
Dave Klimas
Ramona, CA
Rebel #472
Brian,
It
engine mounts.
design
are
field
Alister
Subject: Re: c of g
Hi Alister
3/4
Best Regards
Brian #328R
have
movement
wheels
factory
heard
weight,
up
keeping
it
have
softer
will
flights,
lots.
would
be
g
an
should
all,
is
course,
forward
have
16.8"
all.
adjust
on
experience
meeting
how
build
g
by Mike Davis
Received: from aws1.bp.nrl.navy.mil [132.250.13.17]
(HELO localhost)
by alpha1.tf.bp.nrl.navy.mil (AltaVista Mail V2.0J/2.0J BL25J listener)
id 0000_0056_37c1_8f88_5c97;
Mon, 23 Aug 1999 14:14:32 -0400
Received: by bpvax.tf.bp.nrl.navy.mil (UCX V4.2-21, OpenVMS V7.1 VAX);
Mon, 23 Aug 1999 18:07:49 -1233
Message-ID: <009801beed93$14a29f90$b300a8c0@tf.bp.nrl.navy.mil>
References: <000401beed8f$a33f6660$14640a0a@tim>
Date: Mon, 23 Aug 1999 14:06:32 -0400
MIME-Version: 1.0
X-Priority: 3
X-Mailer: Microsoft Outlook Express 5.00.2014.211
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2014.211
I think the clarification you are looking for can be found in the following
archived message...
http://www.dcsol.com/murphy-rebel/lists ... 000120.htm
To: 'Murphy Rebel Builders List' <murphy-rebel@dcsol.com>
Sent: Monday, August 23, 1999 1:46 PM
Alister:
Tim
